03-10-2010, 09:55 AM
#1
Bathroom Fan Vent
Installing a vent for my bathroom fan. I just saw that I didnt have one and it was emptying into the atttic. Do you run it to the roof or can you take it out to the fascia board below the guters - could put a vent cover on it? What do you think? bad idea?
03-10-2010, 12:35 PM
#2
Commercial Roofing
Bathroom Fan Vent
I say run it through the sidewall if possible... they make nice parts to do this.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
The Following User Says Thank You to AaronB For This Useful Post:
03-10-2010, 12:59 PM
#3
Bathroom Fan Vent
HD or lowes have the venting kits for sale for like 20 bucks, you can find them at the vent display... you can choose between venting out the roof or wall depends which one you are more comfortable installing.
The Following User Says Thank You to Stephen S. For This Useful Post:
03-10-2010, 02:17 PM
#5
Newbie Bill
Bathroom Fan Vent
I'd think running the vent through the fascia would be more difficult than running it through the roof. And I suggest you do NOT install the vent in the soffits. So wall or roof, but not soffits.
See this thread on the topic.
bath fan questions
Bill
A DIY Noob that knows just enough to be dangerous.
03-10-2010, 02:31 PM
#6
Bathroom Fan Vent
Gruntman, yes it's something like you posted. I believe the ones in HD or Lowes come with a pipe, zip tie, etc, even better.
03-10-2010, 02:32 PM
#7
Bathroom Fan Vent
Nice threads - thanks. I see the problems with mounting the vent right under a vent that would then suck the air right back into the attic. I dont have soffit vents in my house so perhaps this would not be an issue for me.
03-10-2010, 04:48 PM
#8
Bathroom Fan Vent
I ran mine out the sidewall of the gable end. Anything I can do to avoid roof vents and skylights in this Northeast climate I will do. Venting into the attic is a very bad idea. Mine from the previous homeowner stopped about 2 ft from the gable vent fan. I extended it out to a proper vent similar the the one in the link.
03-10-2010, 05:02 PM
#9
Bathroom Fan Vent
straight up the the roof would be my recommendation,when you have bends etc. in the tubing it tends to accumulate crap in there,run it straight up,and cut off any extra tubing . talking shingle type roof though,need something totally different for a flat roof
03-10-2010, 07:02 PM
#10
Bathroom Fan Vent
I agree, straight up through the roof makes the most sense as long as you have the knowlege and skill to properly seal it from leaks. The one in my first floor addition is through the roof. I just make sure the snow is cleared from around it with a roof rake, which is one of the smartest purchases I have ever made.
03-10-2010, 09:16 PM
#11
Commercial Roofing
Bathroom Fan Vent
I say that since this is just a fart fan, and not a dryer vent, then go through the side wall. This will eliminate a penetration through the roof without anything accumulating within the pipe.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
