Bathroom Exhaust Fans - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-03-2011, 08:28 PM   #1
Bathroom exhaust fans
Need I be very worry about water leaking from my bathroom exhaust fan?
blkprlgrl is offline   Reply With Quote
Old 02-03-2011, 08:33 PM   #2
Rewards Points: 286
Yep. You need to figure out where that water is coming from and correct it. Water causes damage and promotes mold growth.
Jim F is offline   Reply With Quote
Old 02-03-2011, 08:44 PM   #3
RFN-4A-LVN
Roofmaster417's Avatar
Great reply Jim F, and NOT to mention WATER AND ELECTRIC don't get along together.I would NOT USE THE EXHAUST.If you are a DIY'r then post some pix.Lots of qualified people here to help.But until you get this fixed, DO NOT USE THE EXHAUST.
Roofmaster417 is offline   Reply With Quote
Old 02-03-2011, 10:37 PM   #4
Registered User
Rewards Points: 526
If you have easy access to it in the attic, check to see if it is flex ducting, which traps condensation easily and could drain down and out the fan exhaust port. Before this, pull the grill cover off or down (while the fan is off) and look carefully to see to source of the water. Either inside the ducting or outside and on the fan box or outside ducting.... A picture would help....
Gary
Old 02-05-2011, 06:20 AM   #5
I too had the similiar problem. I climbed into the attic and found that they had use uninsulated flex pipe, which was covered with "blown" insulation, however one section that rose up over the joist was bare and exposed to the cold. I wrapped that section with pink insulation and had no further problems.
jsaf is offline   Reply With Quote
Using Bathroom Exhaust During Demo DetroitEE Building & Construction 10 01-17-2011 02:32 PM
adding can lighting and bathroom exhaust fan to aluminum wired house matjam68 Electrical 2 03-22-2010 10:50 AM
Basement bathroom exhaust fan install krusty HVAC 5 09-15-2009 07:41 PM
Basement bathroom exhaust fan sjahan22 HVAC 5 06-09-2009 09:32 AM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 07:59 AM
