Batch Codes On GAF
What do the batch codes look like on the paper wrapped bundles of GAF shingles? I see the numbers A 2044, BA 21 09 and BA 21 10. I just want to make sure all is OK color/batch wise.
I would also like to know if there is a difference in shingle quality from the different plants? I have heard that some places carry inferior shingles in the same brand. Some say bundles wrapped in plastic are 2nd rate quality. Whats up with that? Thanks, for all the help you guys have provided me. I really do appreciate it. As a matter of fact I would like to thank you on behave of everyone that you have taken your time to answer questions and give guidance. You all do a swell job!:yes: |
Group Hug!!! :eek:
Call GAF directly regarding the slight difference in the one set of numbers. They keep us in the dark usually. Ed |
I notice on the TOP SIDE part of the GAF 30 year shingle the main 1 1/8" glue strip is positioned all the way up near the edge of the shingle . There is no glue strip along the nail line. There is a dotted glue strip pattern on the underside at the lower part of the exposure area part of the shingle. I presume this will glue the shingle down so wind won't lift it.
The GAF 50 year ULTRA shingle is quite different. The main 1 1/8" glue strip is located on the underside of the shingle right along the nail line. The dotted glue strip is located topside just above the nail line. I know this is a kinda who cares question, but inquiring minds want to know. Anyone know why they do this? |
Malcolm, Funny you should say that. I very recently saw a ad for Owens Corning at Lowes on all 30 year or better shingles 25% off. By the way not all timberline 30 year are wrapped in paper. I have a couple of bundles left from my shed and they are in plastic. The 50 year ones I got today are in paper.
I'm kind of confused by your description. There should only be one glue line. GAF uses a spotted glue strip. The 1 1/8" strip you must be referring to is the plastic that keeps the shingles from sticking together in the bundle. It should line up with the adhesive strip on the shingle when the package the bundle. |
I think I understand. The 1 1/8" wide strip, the one you could actually peal the thin plastic cellophane of off if you wanted too... Is actually not a glue strip at all. Is that right?
Years ago, as I remember, when I put on my current roof the 1 1/8" strip was the glue line. As the roof heated up the glue would melt thus sealing the shingles to each other. Of course, I may not remember that correctly.:laughing:. |
GAF ULTRA 50 yr $19.13 per bundle or if you prefer $76.52 per sq. Slightly less than what Home Depot sells it for in this area. I could have got it at Bradco for 73.55 a sq. but I would have had to circumvent the guy thats doing the job. I spent a little more by letting him get the materials but he is saving big time on the labor for the ripoff. Also he will replace as a courtesy under layment as needed which I will supply up to 3 sheets. Should only need one. More than that and we will need to work something out.
When did you buy your Owens Corning? |
Bradco was the least expensive of any shingle I priced, including Elk, Certainteed, and Tamko. I don't know if the sale on Owens Corning is still on at lowes or not. I think it is though.
Same size roll?
They are the exact same. I actually needed one more delivered with my shingles. I had to show the guy at bradco my receipt to do a price match. He couldn't believe they were selling them that low. Bradco's ice and water was higher than abc supplies as well. |
| All times are GMT -4. The time now is 04:18 PM. |
