Basement Problem... But Is It Really The Roof!? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-06-2012, 07:43 AM   #16
Rewards Points: 1,452
One additional thought. Shouldn't there be Tyvek house wrap or something similar under the siding? Wouldn't the water that gets behind the siding run down the wrap and exit at the bottom of the siding? I don't think the water should be able to get behind the house wrap and into the wall which leads me to think it's getting in around the window. Thoughts?
mikegp is offline   Reply With Quote
Old 06-06-2012, 08:48 AM   #17
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,286
Originally Posted by shazapple View Post
There are a couple possibilities here
1) Either rain is overshooting the eavestrough or it is filling and spilling over. Wind pushes it against the siding where it runs down into the vinyl trim at the top of the window, where it is channeling water to the corners. From there it can get in behind the siding and down into the basement.
2) The trim at the bottom of the metal fasica may also be allowing water behind the siding. Water seems to be traveling between the fascia and eavestrough because of a poor drip edge.
Overall you wouldn't have this problem if it was a house with overhangs.
Edit: I basically said the same thing as Dan, his coil stock idea is a good one!
+1
Fix the gutter issue first whatever the root cause is.
Old 06-06-2012, 08:17 PM   #18
Rewards Points: 1,294
The only way to verify that is to unhook a piece of vinyl and look. My money would be on none. I have seen too many vinyl jobs done where the concern was apperance and not weatherproofing. By the looks of the picture of the siding under the gutter there is and has been a lot of water running down that siding for a while now. also, water should never be getting behind the siding in the first place.
danpik is offline   Reply With Quote
Old 06-06-2012, 08:31 PM   #19
Is there just j trim on your window or is there a "rain cap" as well?
IntexInspector is offline   Reply With Quote
Old 06-06-2012, 09:27 PM   #20
Rewards Points: 6,652
My house has the reflective mylar type wrap, which was way before Tyvek became the norm. Depending on when the siding job was done, doubtful that it was needed or required at that time. Back in the time before Tyvek, they used to use Visqueen inside the house as a vapor barrior, and on the outside used the fiberboard made by Celotex, that was impregnated with tar as a outer barrier. Problem with Celotex, is that it also was a material known to have Asbestos in the boards.
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 09:00 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
Roof water flow Problem paulssn Roofing/Siding 3 08-29-2009 08:57 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
