Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 10-27-2010, 11:29 PM   #1
Balcony Drain Freeze
We have a small balcony over an outside front entrance. There is appropriate water proofing system(flextile), drain and slope. HOW do you prevent drain freeze- in freeze thaw conditions? Our winters are long with ranges of 0 to -40 c, with everything in between with quick temp changes. We are afraid the pipe will freeze, with water in it. We need to know asap as the roof is being closed in. Our electrician is new to this -doesn't have a clue what heat trace to use, how to keep it safe.
sueann is offline   Reply With Quote
Old 10-28-2010, 12:18 AM   #2
i think the best course is to leverage mother nature-gravity. make sure grading is steep enough that before it freezes it would run off
federer is offline   Reply With Quote
Old 10-28-2010, 09:58 PM   #3
Doing This Way Too Long
Internal drain or through-wall scupper? and,yes, you should be concerned of that.
OldNBroken is offline   Reply With Quote
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 03:25 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 02:46 PM
Condensor drain Captflx HVAC 6 08-17-2008 11:19 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 08:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
