Balancing Attic Ventilation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-10-2011, 08:05 PM   #1
Balancing attic ventilation
Hello,
I have a 1.5 story home with 76 linear feet of ridge vent. I don't know if it's the rolled type ridge vent or not but during an energy audit about 6 months the guy told me it was installed correctly. Based on what Ed said in another post that should give me roughly 1368 sq inches of venting (18 sq inches per linear foot). I also have about 85 linear feet of continuous soffit venting. I have attached a picture of it to help. I am not sure of specs on this soffit vent. It is 12" wide, actually only 11" that can pass air.
My problem is on a 95 degree day, like yesterday, the attic reads 130 degrees. It almost broke the thermometer testing it. And when I am up there I can barely see any noticable airflow. Cobwebs hanging from the underside of the roof hardly move in the channels rising from the soffit vents.
I educated myself on attic sealing and insulation and have done all that was recommended during the energy audit. The soffit vents seem clear and the insulation is not blocking airflow up to the ridge vent. I know powered attic fans aren't recommended with ridge vents.
So, basically I am not sure if my intake is anywhere close to what it needs to be and I am not sure how to calculate it. If it is insufficient then how would I fix it?
Thanks for your input.
Bob
Bob Ramskill is offline   Reply With Quote
Old 06-10-2011, 11:24 PM   #2
Registered User
Rewards Points: 526
Welcome to the forum!
If your soffits are 2' deep from house to fascia, you are probably fine, giving you 4.68 NFVA per foot times two = 9.36NFVA.
http://files.buildsite.com/dbderived...rived92755.pdf
That, plus the other side balance to the ridge vent exhaust NFVA. Personally, I would trust a continuous soffit vent located near the fascia board for better intake and no house pressure: pp.616: http://books.google.com/books?id=Z8a...0vents&f=false
If only 11", you are getting about 4 NFVA, or 1/2 as much as you need.......
Gary
Old 06-11-2011, 06:07 PM   #3
Gary,
Thanks for the info. I have the 11" soffit panels which means I need to double it somehow.
Do you have any ideas on how I might correct it, maybe replace the soffit panels with something else??
Bob
Old 06-11-2011, 11:18 PM   #4
Registered User
Rewards Points: 526
Just pull down the vinyl, add backing framing and continuous vent strips, solid vinyl or cement board.
http://www.airvent.com/homeowner/pro...it-specs.shtml
Gary
Air sealing, ventilation, and attic insulation project-need advice Badfish740 General DIY Discussions 4 06-01-2011 06:48 AM
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-02-2010 11:38 PM
Old Basement venting & Attic Ventilation RyanPaq HVAC 0 11-16-2010 04:10 PM
Attic Ventilation in 1928 Bungalow stephensandlin Roofing/Siding 1 07-09-2009 11:16 PM
attic ventilation lou1968 Roofing/Siding 5 05-31-2009 09:33 PM
