Bad Domer By Roofing Company - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-06-2008, 10:32 PM   #1
Bad Domer by Roofing Company
This is the way our roofers did this dormer. It was not this way before and did not leak. We have researched dormers and have not seen anything like this.
Our roofer is telling us there is nothing else to be done and that this is the only way to do this dormer. We are looking for advice on how to deal with this problem and where we can find examples and plans for roofing dormers like this.
deretta huey is offline   Reply With Quote
Old 05-06-2008, 11:35 PM   #2
There's no excuse for "workmanship"like that.I would make them re-do that area,looks to me the cuts are too tight and flashings aren't secured properly.Does look hideous as you know already I'm sure.Keep phoning them over and over until they resolve this issue,although you may be better off getting someone else to do this...as this is how"they do it"
johnk is offline   Reply With Quote
Old 05-07-2008, 08:57 AM   #3
WOW. No flashing on the wall and it might be the same way on the other wall.Bad cuts.Shame on them.
mark942 is offline   Reply With Quote
Old 05-07-2008, 12:54 PM   #4
i cannot comprehend things like this
AndyH is offline   Reply With Quote
Old 05-07-2008, 02:08 PM   #5
It looks like they used a flexible sheet membrane, such as the Tan version of Duro-Last as the window sill flashing.
I did that once also, but it definitely came out looking better when we did it.
The excessive shingle overhang over the window pan sill is relatively easy to trim and so are the shingles that are butted too tightly to the wall.
The lifting of the shingles is due to the sheet metal not being bent to the correct angle of the roof slope and how they attached it to the wall.
It may still wind up being a Pig when rectified, but at least it wil be wearing perfume.
Ed
Ed the Roofer is offline   Reply With Quote
Old 05-07-2008, 03:06 PM   #6
Rewards Points: 258
Hi Ed, Looks like the shingle lift is due to the shingle being cemented down just before the improper metal angle. (With regard to the bottom shingle on the membrane)
My roof wears the finest imported perfum... Eau de Ripoff
Docfletcher is offline   Reply With Quote
Old 05-07-2008, 10:01 PM   #7
the roofing god's Avatar
Send a message via MSN to the roofing god
basically sloppy workmanship,sad ,get them to fix it,and remind them word of mouth recommendations work both ways
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 05-18-2008, 03:32 PM   #8
BUILDER / REMODELING CONT
buletbob's Avatar
What was the price of the job? Workmanship like that, I believe you went with the lowest bid.
I would of pulled all corner boards off and removed the storm panel, pulled window if needed and pan flashed the complete window well (sides apron) with copper and soldered all joints. the sides should of been step flashed also. the job would of been priced accordingly.
Old 05-19-2008, 12:33 AM   #9
The cheapest??
We went with the most reputable roofers around. The cost! 6,500.
I would have thought that they would have done a professional job. But now I have to fight with them to complete this job right. So please don't call me cheap.
Old 05-19-2008, 05:27 AM   #10
buletbob's Avatar
Deretta, I apologize if you miss understood what i was meaning to say.
From the pictures that you have posted, I would of come to the conclusion that the finished product would reflect that the price was cheep! not you . I can't understand why a reputable company would leave something like that, In my opinion, they don't have the knowledge or experience to tackle this type of window flashing.
please except my apologies we are here to help, not condemn. BOB
Old 05-19-2008, 10:19 AM   #11
Just because someone charges high end prices does not mean that they wil be doing high end workmanship.
Thays why it is imperative to check out "Multiple" previous job references and have a very detailed written contract.
Also, most contractors subcontract out the actual work once they sign the job, which then means that you need to check out the subcontractor licensing and insurance and previous committment to quality installations.
How many past jobs that this company did similar to yours, did you go and check out and talk to home owners who used them in the past?
While a cheap price may indicate that they arew skimping on valuable specifications, it may also indicate that the company is a new start up without much overhead, which is a double edged sword. Cheaper overhead means lower prices, but also means a higher potential of them not being around to service the roof properly and possibly not enough cash flow to obtain additional training, since they think they know it all already. It also may spell doom for them to remain in business.
Ed
Lathe metal roofing? Stan ETenn Roofing/Siding 19 06-18-2013 06:48 PM
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 05:10 AM
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing/Siding 9 09-13-2009 05:32 PM
Metal roof??? Tdoggy187 Roofing/Siding 51 03-04-2008 03:35 PM
where is my roofing contractor??? ucfpco Roofing/Siding 3 10-11-2007 11:34 PM
