Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 02-10-2011, 02:50 PM   #1
aura vents vs turbines
I have two old 14" turbines as exhaust for my 1800sq foot attic. One is definitely in need of a new head. I was thinking of replacing them with these Aura vents that have no moving parts. The website, of course, says they are better than the turbines. Does anybody have any actual experience with them? I am also considering adding a third Aura or turbine to the roof. The website is: http://roofvents.com/roof-vent.html
thanks
hage1 is offline   Reply With Quote
Old 02-10-2011, 04:13 PM   #2
RFN-4A-LVN
Roofmaster417's Avatar
IMHO I feel turbines are ineffective.The other vent you speak of I have never installed. So my opinion on that product is useless to you.However I am a firm believer in Ridge vent.If you have soffit the Ridge vent IMO is the best combination.If the cost is an issue which it might be then try the Aura.The cost for Ridge vent might be more than you wish to spend.To properly install the Ridge vent the holes from the turbines will have to be properly closed.(Shingle removal,then install proper decking,then reshingle)
Remove the Ridge cap cut the top of the decking back along the ridgeline according to material specs.Install Ridge vent,then cap,and seal any exposed nails from the closed out cap.
Roofmaster417 is offline   Reply With Quote
Old 02-11-2011, 09:23 AM   #3
Interesting the debate between ridge vents and turbines. The ridge vent seems very logical to me. Unfortunately, I am told to get soffit vents I would need to replace 120 feet of aluminum soffit. The concensus seems to be that you can't just pull out a piece here and there and replace it with a vented piece. As far as I can tell, my roof has only a single "eyebrow" type vent near the edge for intake. Adding a few more of these eybrows and another turbine seems a lot cheaper than a ridge vent and all new soffit. I do have ice dam problems in winter. I just have to add up the numbers for both options and decide.
thanks for the advice.
Tags
attic vent, aura, roof vent, turbine
ridge vents vs. box vents vs. turbine vents redaws Roofing 12 03-12-2012 10:48 PM
Atic: Adding Intake and Exhaust Vents (Maybe Ridge) arcane Roofing 9 07-22-2010 07:20 PM
Ridge vents and roof vents jerry1967 Roofing 4 06-07-2010 06:40 PM
Ridge vents and/or fan? mama2girls Roofing 20 05-27-2009 08:12 AM
ridge/soffit vents not enough?? cbice74 Roofing 1 06-16-2008 06:02 PM
