Attic Windows: How Much To Close Them? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-20-2010, 09:47 PM   #1
Attic windows: how much to close them?
Hi, our house is a 2-story in MA.
The attic is above the 2nd floor and is 700 sf.
There is a jalousie window at each end. 4 ft tall and 2 ft wide. They are hard to turn, but were open as much as I could get them (probably halfway) over the summer.
For the winter, should I close them a bit, or leave them open?
Thanks...
Flexicon is offline   Reply With Quote
Old 12-31-2010, 08:18 PM   #2
Registered User
Rewards Points: 526
Ridge vents, gable vents, pot (turtle or static) vents, soffit vents, etc.; http://www.airvent.com/homeowner/pro...it-specs.shtml
Gary
Old 01-01-2011, 07:44 AM   #3
Residential Roofer
Slyfox's Avatar
If that's the only source of venting your attic, leave them open as much as possible.
Read through the link posted by GBR in WA and come next year you can explore the better options of roof ventilation that will both improve your comfort level in the summer months and mechanical protection from snow build up & ice damming in the winter months.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Pella Windows - Serious Frost Issue snowman72 General DIY Discussions 22 07-08-2011 12:39 AM
replacing windows.. modifying a rough opening by less than 2 inches? diy'er on LI Building & Construction 14 09-18-2010 06:43 PM
Replacing aluminum frame windows gallasm Remodeling 2 01-05-2009 10:03 AM
New Windows in attic - I want cheap and easy Leah Frances Building & Construction 4 05-23-2008 05:52 AM
