Attic Vents/Air Flow Questions - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-05-2012, 10:40 AM   #1
Guys,
The roofer/attic guy who came to look at my leaking skylight also noticed that my soffit vents were not getting enough air into the attic. He recommended some turbine vents to increase air flow and such. Right now, all I have is ridge vents. My roof is called a "hip roof". My second floor is hot during the summer and freezing during the winter, especially in one particular room which he said didn't have any flow above it in the attic. I'm getting conflicting info online that I should be getting more soffitt or turbine is useless without wind, etc. Would turbine make a difference?
need2speed75 is offline   Reply With Quote
Old 10-05-2012, 11:27 AM   #2
Rewards Points: 43
Do you have a continuous ridge vent or individual vents near the ridge? A hip roof normally doesn't have much of a ridge, and you have to use turbines or similar vents.
I do know the importance of adequate soffit venting as I added 40% more soffit louvers, and really noticed the difference in the attic.
However, I dont understand how inadequate attic ventilation would make an upstairs room cold in the winter. That is a different issue altogether.
Al
AlleyG is offline   Reply With Quote
Old 10-05-2012, 11:37 AM   #3
They are individual ridge vents. The guy is saying that since not enough air is coming in through the soffit, therefore, creating a vaccum and thus not enough air is leaving (I'm going to have to brush up on physics)?? This causes not enough airflow which heats/cools the attic effecting the rooms right beneath it?? The turbine vents helps circulate the air more, providng relief. I'm just trying confirm his explaination... Anyone?
Old 10-05-2012, 01:09 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,568
Venting should always be balanced and error on the side of supply.
A 60/40 split is preferable on the intake.
Old 10-05-2012, 01:23 PM   #5
Rewards Points: 2,094
A gambling person would be betting your hip roof attic has an insulation problem rather than a venting problem.
Old 10-05-2012, 02:39 PM   #6
the article from airvent explains the concept very well in detail (http://www.airvent.com/pdf/literature/PAVbooklet.pdf).
as fariview stated, primary cause for that extreme hot/cold for your second floor may be due to incorrect installation or not enough insulation in your attic.
just so that we are on the same page, a ridge vent is at the very peak of your roof. a soffit vent is at the bottom ("eve").
you can calculate the required number of soffit vents here (http://www.todayshomeowner.com/adding-soffit-vents/)
good luck
allthumbsdiy is offline   Reply With Quote
Romex wires in attic questions Lopton Electrical 6 04-18-2013 09:31 PM
Attic insulation suggestions? iwfur25 Insulation 1 07-09-2012 11:50 AM
attic stairs for attic hvac installation scrolup HVAC 1 04-15-2012 12:53 PM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 08:49 AM
attic vent questions Grimace Building & Construction 3 06-13-2009 06:59 AM
