Attic Venting For Small Hip Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-10-2010, 11:57 AM   #1
Attic venting for small hip roof?
I have a small in-law unit in back that currently has no ventilation. It's about 400 sq. ft., probably a detached garage conversion, and has a hip roof. So I have no soffits, no gables, and the ridge is about 2.5 feet long. We don't get any extreme winters but summer gets hot. What would be the best way to ventilate the attic, preferably DIY and not really expensive. Thanks for the help.
kevsmith is offline   Reply With Quote
Old 06-10-2010, 03:12 PM   #2
Install continuous soffit vents around the entire exterior perimeter for the intake ventilation, unless you are planning on installing a new roof in the near future, in which case I would consider Smart Vent, which is an under shingle Intale Ventilation System that I like to use.
For the exhaust, a Solar Powered powered attic ventilator would be your easiest option to consider.
Ed
Ed the Roofer is offline   Reply With Quote
Old 06-10-2010, 05:48 PM   #3
Thanks for the reply Ed, my only problem is that there isn't much of a soffit to work with. It looks like the roof just overhangs maybe an inch from the building, and most of that is shingle. I'm not really familiar with any of this so maybe I am missing something.
Old 06-10-2010, 06:20 PM   #4
Sounds like you'll have to pull air in one roof vent at one end and exhaust it through another at the other end.
For the attic volume the Web has calculators for the volume of a square-based pyramid and the roof volume can probably be calculated by using these formulas.
Old 06-10-2010, 07:25 PM   #5
Thanks Yoyizit, so can I just use a square vent (usually for outflow) for intake low on one side and then use a power vent higher on the opposite side to draw air out?
Old 06-10-2010, 07:50 PM   #6
I don't see why not but you should figure out how many air changes per hour you want for this attic. You'll probably need to know the fan curve for your power vent to size the intake vent for the CFM you want.
http://www.google.com/search?client=...UTF-8&oe=UTF-8
Old 06-10-2010, 08:20 PM   #7
Rewards Points: 1,088
You may want to consider these, although I would caution you that I think these could result in water intrusion if there is ice damming.
If this house does not have gutters, then ice damming shouldn't be a concern.
http://www.airvent.com/homeowner/pro...-theedge.shtml
handy man88 is offline   Reply With Quote
Old 06-11-2010, 11:20 PM   #8
Thanks for all the help everyone. I'll figure out how much air I need to move and go from there. By the way, any solar powered fans that anyone recommends?
Old 06-11-2010, 11:53 PM   #9
Costco sells a solar powered attic fan.
Old 06-12-2010, 12:27 AM   #10
I saw one there a couple of weeks ago. I think it was $299. It looked a little better than the Home Depot ones. Do you have any experience with that particular fan?
Old 06-12-2010, 08:09 AM   #11
I considered putting one in....the only issue with these fans is that they shut off when there's no sun.
Otherwise, it's cost free to run, and they operate year round.
I recommend you read the reviews on their website, which are almost all good.
Old 06-12-2010, 11:10 AM   #12
These solar fans seem to be putting out an awful lot of CFM for very little watts in.
They seem to be off by a factor of 5, in favor of the fan manuf.
I don't believe their numbers.
Tags
attic , hip roof , ventilation
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 12:11 PM
Venting a Hip Roof?? CrossWorks Roofing/Siding 7 04-06-2009 11:56 AM
venting a tin roof Moparman Roofing/Siding 1 07-26-2008 03:12 PM
Attic Fan Venting joedadog Building & Construction 2 02-02-2007 06:05 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
