Attic Venting - Ridge Vents Or Fans? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-03-2008, 10:42 AM   #16
Probably the Best way, but there may be other more practical solutions, would be to use a piece of plywood, wrapped with visqueen and screwed to the interior framing of the opening with some foam gasket air conditioning tape to create a buffer for weather tightness at the perimeters.
Otherwise, just staple a double folded sheet of plastic visqueen to the framing, but you will probably have to replace it every few years due to UV degradation.
Ed
Ed the Roofer is offline   Reply With Quote
Old 07-03-2008, 11:03 AM   #17
Originally Posted by bob22 View Post
Not to hijack the thread, I think this is relevant: what is the best way of closing off the gable vents when a ridge vent is a retrofit? Would metal duct tape applied to the inside of the gable vent last?
tia,
Bob
We would:
  1. pull up a section of the decking
  2. have our smallest, wire-iest guy wiggle in with a tape measure
  3. scream out the dimensions
  4. on the roof, someone would cut a piece of OSB & drop it in
  5. nail it in place from the inside.
  6. put the roof deck section back.
parkerfairfield is offline   Reply With Quote
HOT attic, ridge vent/soffit vent questions gone_fishing Roofing/Siding 36 07-14-2008 09:26 PM
Blocked Attic Soffit Vents on North Side - How to Improve Venting Jes Roofing/Siding 5 05-06-2008 09:35 AM
attic ventilation design help Noreaster Roofing/Siding 15 04-30-2008 08:31 PM
Gables and ridge vents not giving ventilation Texas Heat Roofing/Siding 4 04-25-2008 01:39 PM
sofit vents + gable end vents no ridge vent mattg1970 Roofing/Siding 5 10-18-2007 09:47 AM
