Attic Venting - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-13-2011, 10:04 PM   #1
attic venting
Since installing a high eff. furnace, I get ice on the attic ceiling in very cold weather where the interior bath fans exit into a roof vent, not thru the roof. Icicles form and then melt when the sun comes out, causing ceiling leaks in the bathrooms and wet insulation. How do I resolve this problem. Thanks, Andy
humpy707 is offline   Reply With Quote
Old 09-13-2011, 11:06 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
They exit into a roof vent but not through the roof? Do you mean that they exit into the attic and not through the roof?
What is the ventilation source for the attic?
Whatever the source or venting, you have too much moisture in the attic and that must be addressed by either more ventilation or less moisture or both.
Old 09-14-2011, 11:54 AM   #3
attic venting
Thanks for the reply, The bathroom vent pipes go up into the rood vents, but not thru them, the pipe ends about 1 inch from the roof vent top. There are eight roof vent, about 1 sq. ft each. I had the house for 16 years, never a problem until I installed high eff. furnace that no longer uses the flue vent thru the attic now vents thru the side wall.
Old 09-14-2011, 03:18 PM   #4
Rewards Points: 252
I would say you have to install vents specifically for the bathroom vents (which is best done through the gable roof ends). The way it is now there is no guarantee the moist air exists the attic.
shazapple is offline   Reply With Quote
Old 09-15-2011, 08:30 AM   #5
They need to vented to outside.
The Following User Says Thank You to Windows on Wash For This Useful Post:
AGWhitehouse (09-15-2011)
Old 09-15-2011, 09:57 PM   #6
A special damper vent, such as one similar to this model by Broan, should be installed.
http://www.iaqsource.com/product_ima...product=172638
Broan Model RVK1A Roof Ducting Kit for 4" Duct
Copyright 2011 | National Trade Supply, LLC | All Rights Reserved
The ducting NEEDS to be TIGHTLY Sealed to the exhaust piping on the interior of the vent product.
Ed
Ed the Roofer is offline   Reply With Quote
Old 09-15-2011, 11:20 PM   #7
Registered User
Rewards Points: 526
Be sure to insulate any exhaust ducting from the outside/attic temperature to prevent condensation inside ducting from a hot shower. Try to use straight pipe for ducting rather than flex when making long horizontal runs or vertical runs. The flex, being 4" will help offset the turbulence and pressure loss if exiting the fan at 3". There is twice as much surface area in flex (compared to straight) if not fully stretched, to gather moisture on the inside walls. Insulate the fan housing box and the wiring hole from attic air. Use foil tape and nylon straps (if supplied, as shown) at all connections. Insulate (and support) it well, the pre-made duct/insulation is only R-6-7.
Gary
Old 09-16-2011, 12:41 AM   #8
Gary
Very good add-on advice Gary.
Thanks for the additional input.
Ed
The Following User Says Thank You to Ed the Roofer For This Useful Post:
Gary in WA (09-18-2011)
Tags
tag1 , tag2 , tag3
Attic Project – Venting and Insulation spaceboy Insulation 3 09-08-2011 09:54 AM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
Old Basement venting & Attic Ventilation RyanPaq HVAC 0 11-16-2010 04:10 PM
venting and moisture in attic Alto Roofing/Siding 3 07-29-2010 09:31 PM
Venting of a microwave oven into attic. BobLink General DIY Discussions 2 09-07-2009 04:20 PM
