Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 10-31-2006, 09:53 AM   #1
Attic Ventilation Questions
I have an attic that is 24X20. I think it is called a gable roof (four corners of the house meet at a peak in the middle). There is prolly 9 or so 8 inch by 1 foot soffitt vents around the perimeter (one side of the attic has an addition coming off with a catherdral ceiling so there are no soffit vents on that side).
I have looked and can't seem to find any roof vents anywhere. Suprisingly, when the outside temp is 45 and the inside is 64-the attic is 60 so from what i read that isn't too bad. My question is, how many vents (and what kind) should I put in? Would one just near the peak be enough?
Nick
AllGoNoShow is offline   Reply With Quote
Old 10-31-2006, 12:25 PM   #2
Commercial Roofing
AaronB's Avatar
Measure your attic floor space. Install one sq. foot of net freev vent space per 150 feet of atticc floor space. Please rememberthat the mushroom type vents are usually 50 sq. inches. One sq ft is 144 sq. inches.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 11-01-2006, 08:42 PM   #3
renovations
For future reference if your roof comes to a point at the top it is known as a hip roof, not a gable.
Bonus is offline   Reply With Quote
Old 11-09-2006, 06:48 PM   #4
Thanks for the heads up!
Old 11-26-2006, 01:02 PM   #5
I actually just measured my soffits and did the calculations-I actually have 7.5 square feet of ventilation with just the soffit vents. The attic is only 580 sq. ft. so I have almost double the amount of ventilation required. Considering I am well over the minimum vent amount just with the soffit vents, do I have to add any roof vents? (currently there are none) If so how many should I add and where should i place them (this is a hip roof)?
Nick
Bird Block Soffit replacement options? Heather WA Roofing 4 02-25-2011 11:06 AM
Attic Ventilation - importance of balance FatAugie Roofing 7 08-04-2007 11:57 AM
Q? for Grumpy the Roofer re attic ventilation Ricky D Roofing 16 04-08-2007 02:19 PM
Roof/Attic Ventilation pramos67 Roofing 6 03-30-2007 01:27 PM
Proper Attic Ventilation kmhill35 Roofing 2 04-01-2005 09:11 PM
