Attic Ventilation Issue After New Roof
We just had a new roof put on our 25 year-old colonial house, including a new ridge vent (Shingle Vent II). Attic is finished, with two access doors in kneewall on one side or room. While putting away Christmas decorations behind the kneewall, we discovered lots of moisture on the roof sheathing behind kneewall, and drips from nail heads onto attic subflooring. Never seen this before....After getting the roofer out to inspect, he said we need soffit vents installed to allow correct ventilation of roof, and to prevent heated air from being drawn into the unheated spaxce behind the kneewall (which is insulated). The previous owners had the attic finished, and the contractor did install stryrofoam proper vent behind the ceiling insulation, but it appears crushed, so not sure if I should proceed with installing soffit vents (was going to use 3 inch round), since there may not be adequate air flow behind the insulation up to the ridge vent.
Shouldn't the roofing contractor have informed us of the fact that without soffit vents, the ridge vent they were installing would not function properly? How should I proceed to improve ventilation in my attic? I also need to add insulation around the access doors in the kneewall and around some of the heating ducts hat feed the upstairs bedrooms which are visible and not fully insulated in the floor behind the kneewall in attic, to decrease air/heat flow into the uncondiitoned space behind kneewall. Thanks, PCinCT |
http://www.icc-es.org/reports/pdf_files/BNBC/97-22.pdf
A ridge vent is pretty useless without a soffit vent. Did they install Storm and Ice shield at the bottom of the roof? With out see what you have now it's hard to make suggestions, also we have no idea where your located. Having uninsulated heating ducts in an unheated space is a great way for condinsation to form. |
Yes, they installed 36 inches of Ice and Water shield at the bottom of the roof. I can take pictures and post if that would help (I am new to this site, so may need some help on how to post photos). PCinCT |
Here you go: http://www.diychatroom.com/f98/
#3, and 4 down the list....... "Having uninsulated heating ducts in an unheated space is a great way for condinsation to form."----- I think Joe hit the nail on the head, check for attic access door weatherstripping also. Gary |
Picture from outside would help as well.
Is there an overhang and enough for soffits? |
| All times are GMT -4. The time now is 04:38 PM. |
