Originally Posted by Jim Rambo
I recently installed perforated vinyl soffits. Ihe soffits were installed over plywood with continuous metal venting. The perforated vinyl soffit is the same as is installed on all new home construction. Will the little holes in the vinyl soffit allow proper air ventilation flow through the covered/existing metal venting into my attic? I live in Georgia and the temperature in my attic is very high. I am not sure what my roof pitch is although it is very high. My insulation does not cover the vents. I have a continuous roof vent. Does a gable mount fan improve or defeat air ventilation in the attic? Thanks!
Before installing a fan, make sure the attic is air sealed. If there are penetrations from below, a fan can de-pressurize the attic causing conditioned air to be pulled from inside.
It sounds as if the soffit vents have been somewhat restricted by adding the vinyl vents over them. I suspect the input is not as good as it was before the vinyl was added, which makes air sealing more important.
