Attic Ventilation
we would close the power vents,install continuous ridge vents,and close the gable vents,because as Dale says they interfere with air flow for proper cross ventilation,you should have enough soffit intake,although it`s easier to calculate if you give dimensions rather than sq. footage
"If it`s worth doing,It`s worth doing right!!" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
