Attic Ventilation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-27-2011, 03:10 PM   #1
Attic ventilation
Hello and thank you for taking the time to answer my question. I am looking to install additional ventilation in my attic to decrease the temperature during the summer months and to remove stale air ( I dont think I have an issue with moisture)... The volume of the attic space is approximately 1750 cu ft (32ft L, 22ft W, 5ft H).. The volume is actually a bit less, since the roof is sloped on all four sides, not just two. There are soffits installed, but no soffit vents, and there is a gable vent w/ mesh screen at the front of the house. The gable vent is roughly 16in x 16in, which would give me about 1.8 sq ft of intake/exhaust area (minus a few points from the screen).. I know that I will have to install soffit vents if I install an attic fan, but what I would like to know is if I should install the soffit vents first and see if that alone would give me the desired airflow, before going ahead with attic fan installation.. I would also like to know if a 1000 cfm fan would be overkill for such a small attic space, especially since it is not airtight.. Going by the attic size calculations, to perform 10 air exchanges in an hour in a 1750 cu ft space (17500 cfh), I would need only a 300 cfm fan (17500/60).. I also have an old chimney which has some cracks in the bricks, so I do not want to start pulling air from unwanted areas... Also, ridge vents are not an option for me... If you need any more information, please let me know.. I can also provide pictures as well.. Thank you in advance..
- Joe
MonteCarloSS is offline   Reply With Quote
Old 07-27-2011, 04:12 PM   #2
AGWhitehouse's Avatar
Don't want to sound rude, but myself and others have typed ALOT of posts about this exact topic. Do a search on this site for ridge vent, attic venting, etc. Take a read, jot down some notes, and then post back if you've got a specific question afterwards. I know for a fact there is all sorts of information on here are ventilation requirements and options.
Life's too enjoy it!
AGWhitehouse is offline   Reply With Quote
The Following User Says Thank You to AGWhitehouse For This Useful Post:
seeyou (08-01-2011)
Old 07-31-2011, 08:33 PM   #3
I looking for a Model R-26 Attic Ventilator fan motor model A051082008
henrym is offline   Reply With Quote
Attic ventilation project AKH Roofing/Siding 3 07-15-2011 07:13 AM
Air sealing, ventilation, and attic insulation project-need advice Badfish740 General DIY Discussions 4 06-01-2011 06:48 AM
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-02-2010 11:38 PM
Old Basement venting & Attic Ventilation RyanPaq HVAC 0 11-16-2010 04:10 PM
Attic Ventilation in 1928 Bungalow stephensandlin Roofing/Siding 1 07-09-2009 11:16 PM
