Attic Ventilation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-12-2011, 11:02 AM   #1
Attic ventilation
Recently I got my roof replaced. The contractor installed ridge vent at top. Before that I had gable vent on one side and an attic fan on the other side of gable vent (my central a/c-heating unit is in the attic). The contractor repeatedly said no need to cover the gable vents but just unplug the attic fan and not to run it. He says the gable vent infact helps air culation. Reading on line suggestions everyone says I should close the gable vent to avoid short-circuit. Any suggestions?
Xpressmyself is offline   Reply With Quote
Old 06-13-2011, 12:10 AM   #2
Registered User
Rewards Points: 5,204
The powered fan will suck some intake air from the ridge vent..from the closest, easiest air supply. If you block the ridge, it may suck conditioned air from below, even back-drafting gas appliances (worse case). I feel if you cut power but leave it in place, the gables and ridge will act as exhaust if they are located more than 3' above the soffit (intake) vents. http://www.nrc-cnrc.gc.ca/obj/irc/doc/pubs/bpn/57_e.pdf
http://en.allexperts.com/q/Roofing-1...able-Vents.htm
http://www.nachi.org/attic-ventilati...s-part1-25.htm
http://www.advancedenergy.org/buildi...%20Studies.pdf
Gary
Air sealing, ventilation, and attic insulation project-need advice Badfish740 General DIY Discussions 4 06-01-2011 07:48 AM
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-03-2010 12:38 AM
Old Basement venting & Attic Ventilation RyanPaq HVAC 0 11-16-2010 05:10 PM
Attic Ventilation in 1928 Bungalow stephensandlin Roofing/Siding 1 07-10-2009 12:16 AM
attic ventilation lou1968 Roofing/Siding 5 05-31-2009 10:33 PM
