Attic Ventilation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-14-2011, 12:09 PM   #1
attic ventilation
Hi all,
Last summer I had insulation sprayed into my attic to the tune of R38, along with the recommended baffles to circulate air over the top of the insulation via the soffit. There were only six baffles put in which doesn't seem like enough for a 1700 sq ft home. My question is that enough baffles to circulate air to my ridge vent? If not can I open the soffet vents and shove new baffles up through the batts into the attic? There are also gable vents, do these need to be blocked in order to increase proper flow?
Thanks!
mulherin31 is offline   Reply With Quote
Old 04-14-2011, 05:19 PM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
What kind of insulation?
seeyou is offline   Reply With Quote
Old 04-14-2011, 05:33 PM   #3
Rewards Points: 1,088
Originally Posted by mulherin31 View Post
Hi all,
Thanks!
The more intake (soffits) the better.
handy man88 is offline   Reply With Quote
Old 04-14-2011, 06:00 PM   #4
The insulation is blown fiberglass I'm pretty sure. I agree the more baffles the better, my question for you guys would be, can I open the soffit vents and punch through the batts with a baffle from the outside? If I were to attempt to install new baffles from the inside I would compact the insulation and essentially ruin the blown insulation effect. What do you think?
Thanks!
Old 04-14-2011, 06:08 PM   #5
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Thanks!
If the soffit vents are large enough to poke the baffle through, I don't see why it's not worth a try. Can't say for sure. Leave the gable vent open.
Old 04-14-2011, 06:44 PM   #6
Thanks!
That really depends on the type of baffle you use. If you use the styrofoam type, most likely it will adversely impact the rigidity of the baffle. Also, baffles are intended to be stapled onto the roof sheathing/rafters, not just put in place.
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-03-2010 12:38 AM
Old Basement venting & Attic Ventilation RyanPaq HVAC 0 11-16-2010 05:10 PM
Improve attic ventilation? Greenmaze Roofing/Siding 28 07-22-2010 03:16 AM
Attic Ventilation in 1928 Bungalow stephensandlin Roofing/Siding 1 07-10-2009 12:16 AM
attic ventilation lou1968 Roofing/Siding 5 05-31-2009 10:33 PM
