Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 06-11-2010, 03:58 PM   #1
Attic vent
I have 3 vents on my roof along with an attic fan. I noticed that all the soffits are blocked by insualtion and it's hard to get to. For the time being, am I better off keep the attic fan off since their is really no intake air and to prevent sucking air from the living space? When I pop open the opening to the attic, you can defiantely feel current from the fan.
timchi29 is offline   Reply With Quote
Old 06-11-2010, 05:08 PM   #2
Household Handyman
Attic vent
Do you have a "gable" or "hip" style roof? IF a gable roof style you should have vents in the ends of the gable which would allow some air flow. IF a hip style roof then your only venting my be in the soffits. It sounds as if you do have a hip style roof with the air movement by opening the attic access. In order to properly ventilate the attic space you will have to pull back the insulation covering the soffit vents. Maybe this winter. David
Old 06-11-2010, 05:36 PM   #3
Attic vent
It's a gable and I realize I have to open up the soffits, but the question was regarding the attic fan.
Old 06-11-2010, 08:55 PM   #4
Attic vent
A lot of people would argue here that the vents in your attic serve as the intake for your attic fan.
handy man88 is offline   Reply With Quote
Venting Bathroom Fan through Attic to soffit vent, vancouver island noonatak HVAC 2 05-12-2010 09:07 AM
Open Bean no Attic Bath Vent cdrusds HVAC 0 10-08-2009 04:46 PM
Trying to Vent Attic Properly stephensandlin HVAC 4 08-03-2009 12:15 PM
Soffit Vent Sizing - Really Hot Attic dmo069 Roofing 7 12-04-2008 10:33 PM
is an attic vent required for cedar shingle roof? walenta Building & Construction 2 10-25-2007 11:31 AM
