Attic Is HOT After New Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-12-2014, 12:45 PM   #1
Attic is HOT after new roof
It was around 70 degrees inside this past weekend, outdoor around 75. The temperature in my attic hit 100 degrees. Is this normal?
We had a new roof put on last September, a "rip" not a re-layer. The roofers suggested I go with an attic fan since the current setup used an attic fan. So he installed a new attic fan and set the thermostat to 95 degrees. My roof has 2 gable louvers on each side and only the front has soffits- Another reason for going with the attic fan over a ridge vent. I'm not sure that the front soffits are functional for air intake.
I called the roofer and he sent someone to pull back the insulation that might be blocking the air intake from the soffits. This did not help.
My concern is that it is not even summer yet and my attic is already getting up to 100 degrees. I'm not sure if this is too hot. Also I don't want the attic fan running 24/7 as it is pretty loud and wasting $.
Anyone have any advice?
johnblanker is offline   Reply With Quote
Old 05-12-2014, 01:14 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,882
Make sure the venting is correct is the first place to start.
100 degree attic with 70-75 degree ambient temps is pretty normal.
What was the shingle color before?
Old 05-12-2014, 01:32 PM   #3
we moved into the house last August and had the roof done in Sept, so we weren't there prior to the new roof. I'm thinking the insulation might be blocking the air from the soffits.
It's a tough squeeze to get to the soffit from from in the attic. I wonder if I had someone shine a light at the soffit from outside at night and then go into the attic to see if I can see the light at all?
Old 05-12-2014, 02:57 PM   #4
Rewards Points: 402
You can try shining a light and see if it works. I had soffit vents and found out after 20 years, the vent holes were clogged up with dust and dirt. Not insulation, that was blocked from coming to the soffits, but just dirt, moisture forming a hard crusty layer. Had to have all the soffit vents replaced.
taylorjm is offline   Reply With Quote
The Following 2 Users Say Thank You to taylorjm For This Useful Post:
gregzoll (05-12-2014), MTN REMODEL LLC (05-12-2014)
Old 05-12-2014, 03:52 PM   #5
Rewards Points: 768
As long as the attic fan is working, I wouldn't be overly concerned about it. Attics with proper ventilation are still really hot.
cibula11 is offline   Reply With Quote
Old 05-12-2014, 06:42 PM   #6
Rewards Points: 1,088
The fan won't run 24/7 b/c once the sun sets, it will start to cool quickly.
handy man88 is offline   Reply With Quote
Old 05-13-2014, 02:17 PM   #7
Well, the fan WILL be running most of the day throughout the entire summer. I'd rather not pay for that.
Old 05-13-2014, 02:23 PM   #8
These rafter vents would have ben a good idea. Shouldn't this have been done by the roofers!?!
Old 05-13-2014, 02:23 PM   #9
Can't post the link
Old 05-13-2014, 02:43 PM   #10
Rewards Points: 402
Well do you want your attic cooler? Nothing is free anymore. If you wanted free you should have made sure the roofers checked the soffit vents were clear, put in a ridge vent and blocked the gable vents.
The Following User Says Thank You to taylorjm For This Useful Post:
roofermann (05-13-2014)
Old 05-13-2014, 03:13 PM   #11
Sure, in hindsight. But I'm not a roofer. I try to understand as much as I can but leave most of it to the "Professionals". It's afterwards when things don't seem quite right that I start to investigate.
My roofer said that he could come back and put a ridge vent in, but I only have soffits on the the front of the house. Not sure if that would be enough intake for passive cooling. As far as cost, I calculated a 3oo watt fan running 8 hours a day to be about $7 a month. That's a long time to see a return on investment if I had the roofers install a ridge vent.
I also forgot about my side gable vents. Even if the insulation was blocking the soffits in the front, shouldn't the attic fan pull air in through those gable vents?
Old 05-13-2014, 06:36 PM   #12
Ultra Windows's Avatar
The problem with power vents/attic fans is that they are going to pull air from somewhere. Ideally, you've got adequate intake to exhaust ratios. But in your case, I'm not so sure. If the intake into the attic is not sufficient, the attic fan can start pulling air out of the conditioned space through cracks and light fixtures. Your roofer really needs to check and see that your attic has a balanced airflow.
Ultra Windows is offline   Reply With Quote
The Following 2 Users Say Thank You to Ultra Windows For This Useful Post:
HomeSealed (05-13-2014), Windows on Wash (05-14-2014)
Old 05-13-2014, 08:33 PM   #13
roofermann's Avatar
Rewards Points: 401
Guess what? Attic was hot before new roof.
roofermann is offline   Reply With Quote
Old 05-13-2014, 09:22 PM   #14
Guess what?
Your fan will run most of the day throughout the summer even if you add soffits and increase ventilation.
Old 05-14-2014, 11:52 AM   #15
Make sure you have enough insulation and turn the stat up.
Attic Insulation with a new roof indigo Insulation 11 03-19-2014 12:22 AM
Metal roof and need attic ventilation celyinsc Roofing/Siding 0 11-13-2013 09:56 AM
Attic Venting With No Roof Overhang jonathan03 Roofing/Siding 4 07-20-2012 11:11 PM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 04:07 PM
attic roof supports Robare Roofing/Siding 0 09-16-2010 01:51 PM
