Attic Foam Board Insulation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-04-2010, 11:27 PM   #1
Hi Everyone,
In the attached picture, you can see area D. I already have insulation on the floor of the attic (area's B and A). However, I don't have any insulation in the D area.
I was thinking about adding Celenit for Insulation of flat and sloping roofs INSIDE the attic. I'm not sure about what the pro's and con's would be. I'm not sure what other materials I could use or what would exactly be proper for insulating the attic inside the slopping roof.
Alternatively, it seems like I could just pick up some Rmax 1" x 8' x 4' R-5.9 Insulated Sheathing and put it in-between the beams in area D of the attached picture. It seems light enough to cut and bring into the attic. However, i suppose it's foam, and so I am not sure about the safety of it?
I've attached a picture of the Rmax panels.
I am wondering about the safety of this? Or what is that I should consider when insulating the roof of the attic?
FYI, I live in California. My goal is to keep more heat out of the attic since I use it for storage. And to keep the attic cooler to avoid the house in general from getting hot when the sun is blazing outside.
Thanks,
Jason
JasonCA is offline   Reply With Quote
Old 10-05-2010, 11:51 PM   #2
Registered User
Rewards Points: 5,468
Check with your local B.D. for covering the foam. http://www2.iccsafe.org/cs/committee...E_06_64_07.pdf
Five Counties in CA would be better adding insulation above the ceiling than a radiant barrier:
Check your location and R-value there now: http://www.ornl.gov/sci/roofs+walls/radiant/rb_02.html
Gary
Gary in WA is online now   Reply With Quote
Old 10-06-2010, 03:35 AM   #3
looks like you are making an unvented attic with its space conditioned like the rest of the house.
this is often done by sprayfoaming between the rafters or even dense pack cellulose. the buildingscience.com website talks about this method.
another way to leave the rafter bays empty and attach foamboard to the underside. in this scenario, you could also turn the empty rafter bays into
a vented one by adding soffit and ridge vents. youll need to cover the foam with sheetrock. that will add some weight so check the rafter size. its kind of hit or miss with building codes. some jurisdictions support \unvented attics and some dont.
rodeo is offline   Reply With Quote
Old 10-07-2010, 12:56 AM   #4
Rewards Points: 956
for my roof i think i am going unvented. apparently its the 'new' thing to do
federer is offline   Reply With Quote
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 10:50 AM
Attic insulation and soffit venting zacker Building & Construction 1 07-15-2010 10:17 PM
exterior insulation foam board sheathing firemem Building & Construction 5 04-29-2010 06:51 PM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Attic Insulation - Do's and Don'ts reikiray HVAC 1 07-27-2007 10:21 AM
