Attic Fans Suggestion Please - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-16-2012, 12:18 AM   #1
Attic Fans suggestion please
i have a concrete tile roof & it primarily has 'soffit' for intake (I see continuous soffit vents around the roof). There are 4 or 5 domer style vents near top portions of the roof. I have been thinking about adding fans just below the domer vents so that it can push air out? Installation will be very easy since I just have to get fans & install just below the domer vents (i don't plan to open the roof or anything - just install fans to blow hot air out thru' the existing vent openings). Will it help? I live in Northern California - we get a few really hot days & a few cold days. I am wondering if adding couple of attic fans (either solar or electric powered with thermostat) will be a good idea? What else should I consider for the attic. No molds, attic looks reasonably clean & house is 12 years old. Will adding attic fans help in Summer? I run A/C only few times during summer.
Appreciate your thoughts/input.
Thanks,
-venvis
venvis is offline   Reply With Quote
Old 11-16-2012, 12:30 AM   #2
Rewards Points: 12,886
Got a picture of the house?
Why not gable fans?
The Following 2 Users Say Thank You to joecaption For This Useful Post:
COLDIRON (11-16-2012), Windows on Wash (11-16-2012)
Old 11-16-2012, 10:20 AM   #3
Roofmaster
Rewards Points: 2,172
Domer Vents?
Do you mean Gable end Vents?
Old 11-16-2012, 10:44 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 852
One of the mods here has a great link regarding attic venting and the use of attic fans....and what you should really have...
As an FYI....my roof has gabble vents....a few years ago I installed an temp controlled fan on one of the gable ends. 2 Problems.....1st...half the time the wind was blowing against it thus making it basically useless. 2nd...It didn't really move much air.
I installed one of those spinning vents on top....it does a much better job of venting.
I have fan for sale if interested.
Old 11-16-2012, 11:34 AM   #5
Rewards Points: 452
You are worrying about things that don't need worrying about . If the outdoor ambient reaches 100F + for 30 to 40 days then you can worry about your attic . Life is short, find something fun to do .
SeniorSitizen is offline   Reply With Quote
Old 11-16-2012, 04:13 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
https://www.google.com/url?sa=t&rct=...dDIlfuLNFbTBHw
Try here...
Old 11-16-2012, 04:19 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 852
Originally Posted by Windows on Wash View Post
Just read that.....very similar to what I had read last year.
Technically, I can't find any fault with it. And based on my experience with my attic fan....I agree.
attic stairs for attic hvac installation scrolup HVAC 1 04-15-2012 01:53 PM
Air sealing, ventilation, and attic insulation project-need advice Badfish740 General DIY Discussions 4 06-01-2011 07:48 AM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 06:06 AM
thermostat and humidity controls for electric attic fans lowlysubaruguy Roofing/Siding 2 09-25-2008 08:32 AM
Attic venting - Ridge vents or fans? jebmke Roofing/Siding 16 07-03-2008 12:03 PM
