06-08-2010, 10:22 PM
#1
Attic Fan
Does anyone know whether the humidistat option is worth it?
06-08-2010, 10:31 PM
#2
Super Moderator
Attic Fan
Yes it is, especially if you live in a humid climate.
This way, the PAV will operate not only from excessive internal heat, but for the RH content as well.
Ed
Stay Tuned For Our New Informative And Helpful Web Site, Coming Soon
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
06-08-2010, 10:35 PM
#3
Attic Fan
Ed
Interesting though....if you live in a humid environment, you're also drawing humid air into your attic.....whereas with attic air (thermostat), you're generally pulling air from the outside that's cooler than air in your attic.
The way PAV's are marketed though, the humidistat option is used during cold weather where humid air inside the house can get into the attic and freeze up....generally speaking, during winter, the air is dry outside.
06-08-2010, 10:38 PM
#4
Attic Fan
Ed
Since you're a roofer, do you use weather shield for all penetrations through the roof even if the device comes with its own flashing (e.g. pipe collars, dryer vents, static vents, etc.)?
06-09-2010, 12:24 AM
#5
RFN-4A-LVN
Attic Fan
We do.,It has been a really great habit that we have been doing for about 6 yrs.,Does it work? it helps to maximize your roof in that area.,however if these components are not installed properly to begin with all moisture guard does is puts a band-aid on a cut. Moisture guard is actually for any area of the roof that has a better chance of ice daming,leaking at pitch brakes,low slopes etc.We use Weather Guard around the perimeter of chimneys,skylights,we use it along gutter and rakelines,and we use it in valleys,pitch breaks,under vents,pipe flashing.It is some good stuff since it seals around the fastener.
The Following User Says Thank You to Roofmaster417 For This Useful Post:
06-09-2010, 01:13 AM
#6
Super Moderator
Attic Fan
As a matter of fact, I do. It seems as if roofmaster already mentioned most of the areas where we install it also, as an added precaution, but we also apply the Ice and Water Shield where there will be penetrations securing something to the roof as well, such as the lag bolt screws from anj old TV antennae too, or satellite dish mounting brackets.
Ed
The Following User Says Thank You to Ed the Roofer For This Useful Post:
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
