Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 06-04-2010, 11:12 PM   #1
Attic Baffles Question
I am looking to add baffles to my attic so I can eventually add soffit vents.
My question is instead of using those flimsy baffles at stores, can I just use a piece of hardboard or plywood attached to the underside of the rafters like in the photo below? I would stuff in some fiberglass batts in the opening at the bottom to keep out the cellulose.
AtticBaffled is offline   Reply With Quote
Old 06-05-2010, 03:45 PM   #2
Super Moderator
You could, but it would be incredibly more expensive I presume and much more labor intensive for the same results.
Ed
Stay Tuned For Our New Informative And Helpful Web Site, Coming Soon
Ed the Roofer is offline   Reply With Quote
Old 06-05-2010, 05:12 PM   #3
the Musigician
DangerMouse's Avatar
I'll be using accuvent baffles when I do the next side of this house.
They fold in and cover the sill and face staple. Seems the most logical and easiest to me.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 06-05-2010, 06:00 PM   #4
Shut in w/o Home
seeyou's Avatar
What you're proposing will work, but it's going to cut down the depth of the cellulose at the outside edges. I'd go ahead and use the baffles.
seeyou is offline   Reply With Quote
Frost in the Attic 295yards General Discussion 13 12-07-2009 05:27 PM
Attic Insulation question nomad4137 HVAC 1 09-06-2009 07:48 PM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 06:06 AM
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 17 09-06-2008 01:59 PM
Attic Venting/Insulating Question gregt848 Building & Construction 1 11-25-2007 03:33 PM
