Attaching Metal Flashing To Faux Stucco - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-10-2010, 02:29 PM   #1
Attaching metal flashing to Faux stucco
I have areas that the metal flashing is separating from the stucco on my home. What would be the best product to seal these areas?
sdcurt is offline   Reply With Quote
Old 10-10-2010, 03:05 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
oooo don't mess with it unless you know what your sealing is supposed to be ''sealed''
Tom Struble is offline   Reply With Quote
Old 10-10-2010, 05:17 PM   #3
It is, there is/was something there but in some areas it has "pulled apart" leaving small gaps between the flashing and structure, which is allowing water to leak into the ceiling below.
Old 10-10-2010, 05:51 PM   #4
there should actually be gaps between the top of the flashing and the stucco
these areas should not be filled
thats how water exits from behind the stucco.you have any pictures of the affected area?
a bead of caulk should not be the only thing keeping water out of your house
Flashing question where eavestrough meets stucco wall? chadurban Roofing/Siding 3 12-31-2010 06:42 PM
Install Flashing onto existing deck ledger, stucco home Ameekins Building & Construction 1 09-15-2010 06:51 PM
bottom corners on metal or butyl flashing of windows 4just1don Building & Construction 1 09-11-2010 11:58 AM
flashing and stucco sharp Roofing/Siding 22 01-01-2010 09:05 AM
Flashing for New Construction Replacement Windows in Stucco House BigJimmy Building & Construction 10 11-03-2007 01:48 PM
