Attaching Downspout To Stone Wall? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-01-2009, 04:53 PM   #1
Attaching downspout to stone wall?
Hi, I'm looking for a non-intensive way to attach a downspout to a stone wall. I'm not sure if it's real stone, it might even be some kind of moulded plaster. Thanks.
applebuilder is offline   Reply With Quote
Old 07-01-2009, 05:40 PM   #2
Remodeling Contractor
masonry anchors and gutter straps. Or is this a trick question? Drill a hole with a carbide tipped masonry bit using a hammer drill and use tapcon screws or plastic anchors with #10 X 1" SMS screws.
Old 07-01-2009, 06:50 PM   #3
Agreed.
Also, if the stone is flush to the mortar joints, then shoot for the mortar. It will be easier to drill.
Ed
Ed the Roofer is offline   Reply With Quote
Old 07-04-2009, 01:02 AM   #4
Thanks for the advice, I was afraid I'd have to drill into the wall but I guess there's no way around it.
Old 07-04-2009, 01:23 AM   #5
Use a 1/4" Carbide bit by 3 1/2" in length, but NOT a regular drill. You need either a Hammer Drill or a Rotary Hammer Drill.
Drill into the mortar joints if possible and they align correctly, since the mortar is softer than the stone.
Ed
Putting stone on family room wall survivor122 Building & Construction 1 04-29-2009 07:11 PM
Attaching Floor Joist To Solid Core CMU basement wall jrepp Building & Construction 5 04-23-2009 03:57 PM
Best way to cover over brick wall in basement? tigereye Remodeling 4 04-14-2009 11:24 PM
attaching an additon room to vinyl wall visionary Carpentry 1 02-23-2009 07:32 PM
Attaching wood srtips to concrete wall DIY4EVER Building & Construction 11 07-21-2007 11:10 PM
