#1 |
Solutions (handyman)
attaching a deck roof to a house
I am replacing a light weight plastis coverd roof with a solid sheathing and shingle roof. I know the weight is more and want to know if I can lag bolt thhe new ledger to the existing facia board. Wil this offer eunogh strength? The over all deck roof is 12 feet from house to outside edge and 32 feet long. I plan to use 4x4 treated posts for the outside support. Any suggestions/advice?
Thanks, Mark |
#2 | |
attaching a deck roof to a houseQuote:
This is more involved, so I don't know if this is something you want to do. Raise the angle of the roof and have it sit on the house roof. The rafters would be cut to intersect your house roof. You would need to remove some of these shingles to make the transition smooth. Ron Last edited by Ron6519; 04-24-2009 at 11:35 AM. |
#3 |
Xtreme DIY'r
What size rafters? distance between them?
What thickness sheathing? Whats the slope of the roof? Where are you located? |
#4 |
Rafters are 2x8, 16" centre, 7/16 sheathing, slope is 1/12. we are in Alberta, Canada. (not extra heavy snow load.
Thanks. |
#5 |
attaching a deck roof to a house |
#6 |
Ron,
I'm using asphalt shingles over building paper over 7/16 sheathing. Hope this helps. |
#7 |
Here is another question. What is the best way to cut through stucco (installing a window)?
| Display Modes | |
| Roof Deck | greenescapist | Roofing/Siding | 1 | 02-17-2009 10:34 PM |
| Concrete roof on house... problems!! | flipjarg | Roofing/Siding | 6 | 01-24-2009 11:06 PM |
| Attaching pergola to brick veneer house | Mikedks | Building & Construction | 4 | 12-28-2008 01:01 PM |
| Deck on Garage roof | billybarty | Building & Construction | 2 | 02-26-2008 05:33 PM |
| Roof used as a deck - what is a good approach | rogersor | Roofing/Siding | 3 | 09-19-2007 02:05 PM |
