-   -   attaching a deck roof to a house (http://www.diychatroom.com/f9/attaching-deck-roof-house-42883/)
Mark Harvey 04-20-2009 01:30 PM
I am replacing a light weight plastis coverd roof with a solid sheathing and shingle roof. I know the weight is more and want to know if I can lag bolt thhe new ledger to the existing facia board. Wil this offer eunogh strength? The over all deck roof is 12 feet from house to outside edge and 32 feet long. I plan to use 4x4 treated posts for the outside support. Any suggestions/advice?
Thanks, Mark
Ron6519 04-24-2009 11:31 AM
Thanks, Mark
No, you cannot do that. There isn't enough support. The fascia board will hold up a gutter, that's it.
This is more involved, so I don't know if this is something you want to do.
Raise the angle of the roof and have it sit on the house roof. The rafters would be cut to intersect your house roof. You would need to remove some of these shingles to make the transition smooth.
Ron
Scuba_Dave 04-24-2009 08:22 PM
What size rafters? distance between them?
What thickness sheathing?
Whats the slope of the roof?
Where are you located?
Mark Harvey 04-25-2009 11:02 AM
Rafters are 2x8, 16" centre, 7/16 sheathing, slope is 1/12. we are in Alberta, Canada. (not extra heavy snow load.
Thanks.
Ron6519 04-25-2009 11:39 AM
Thanks.
This is basically a flat roof. What's the roofing material?
Ron
Mark Harvey 04-25-2009 07:14 PM
Roof material
Ron,
I'm using asphalt shingles over building paper over 7/16 sheathing.
Hope this helps.
Mark Harvey 04-25-2009 07:36 PM
Here is another question. What is the best way to cut through stucco (installing a window)?
