Attached Carport Problems - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-20-2012, 09:11 AM   #46
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
That rafter looks OK. If the decking is OK and you're not setting the new rafter between old ones. They must bear on a solid surface.
tinner666 is offline   Reply With Quote
Old 06-20-2012, 07:13 PM   #47
Okay, here's how far I got today. I'm starting to worry that I won't be done in time. It's saying possible rain on friday so I need a tarp plan for tomorrow night. With luck I'll have the rafters and OSB in by then.
Attached Carport Problems-p1020155.jpg   Attached Carport Problems-p1020156.jpg
flatroofblues is offline   Reply With Quote
Old 06-20-2012, 07:15 PM   #48
Here are the end of the hip rafters, I tried to taper them to zero. Not perfect, are they good enough?
Attached Carport Problems-p1020157.jpg   Attached Carport Problems-p1020158.jpg   Attached Carport Problems-p1020160.jpg
Old 06-20-2012, 07:18 PM   #49
And the first nailer fell short of going all the way to the roof. That seems like it will be okay but I want to make sure. The next seem too thick where it meets the roof, or will it be okay?
Attached Carport Problems-p1020161.jpg   Attached Carport Problems-p1020163.jpg
Old 06-20-2012, 07:36 PM   #50
Pro Slate Roofer
tinner666's Avatar
Pull strings from dots.
Old 06-27-2012, 09:05 AM   #51
Okay, so after a long weekend of the roofers finishing and one rain that I tarped for successfully, it's all done! The first picture is how far I got on my own, the second is the finished roof. Had I known it would have been dry this long I might have tried to get further but I'm still glad I had someone finish for the actual waterproofing at the end. Just to have some one besides my self to hold accountable lol I ended up going over budget but still did all this for less than the first estimate to just replace the flat roof.
Thanks so much for all your help frank, the roofers who came to give me estimates all said I did a pretty good effort for a newbie and that's all thanks to you. Hope you are well and thanks again for everything
Attached Carport Problems-p1020164.jpg   Attached Carport Problems-p1020178.jpg
Old 06-27-2012, 02:53 PM   #52
Pro Slate Roofer
tinner666's Avatar
Glad to have helped. Call again any time! Using the phone and posting pix to ask and answer in real time was the big factor.
New Dog. Problems. Doc Holliday Off Topic 12 12-26-2011 09:59 AM
Enclosed carport lonnie.seratt Building & Construction 1 10-04-2011 07:10 AM
Carport to Garage cprao Building & Construction 14 05-21-2011 12:01 AM
garage or carport rwfifty Building & Construction 1 03-21-2011 10:32 AM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
