Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 07-02-2009, 11:03 PM   #1
Default assembling copper gutter
hey all,
any tips on soldering together copper gutters and downspouts?
will be tackling this job over the weekend...
thanks.
schmolze is offline   Reply With Quote
Old 07-03-2009, 12:49 PM   #2
http://www.slateandcopper.com/produc...f-round-gutter
bob22 is offline   Reply With Quote
Old 07-03-2009, 01:44 PM   #3
Extreme DIY Homeowner
Scuba_Dave's Avatar
Nice, I like copper...can't afford it right now
Scuba_Dave is online now   Reply With Quote
More On This Topic
Gutters drain rain water away from your home and its foundation. Repair broken gutters as soon as possible to prevent major damage to your home. Aluminum, vinyl, copper and galvanized steel are the most commonly used materials for gutters. Evaluate each... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
Hi this is Ginny with Simply Beautiful Crafts on behalf of Expert Village. If you're making a rain stick with small children and you don't want to poke things into the outside of it or mess with chicken wire, you can use aluminum foil to make a sound... Read More »
Hi, everybody my name is Angela Pugh. I'm the mother of two teenage daughters, for a while I was a single parent. So today I'm here on behalf of Expert Village and I'm here to teach you how to apply for welfare. (demonstrating on computer screen) Read More »
Hi, this is Ginny with Simply Beautiful Crafts on behalf of Expert Village. In order to make your own rain stick, you really need a very limited amount of supplies and almost anything that you need as far as supplies, you probably already have at home. I... Read More »
Squirrels chewing the gutter guards... gshock Roofing 1 04-12-2009 02:47 PM
"Frozen" Gutter Leak cougar01 Roofing 19 02-10-2009 08:07 AM
Flexible copper or Rigid Copper for solar? Piedmont HVAC 5 06-11-2008 11:47 PM
Flexible Copper or Rigid Copper? Piedmont Plumbing 1 06-10-2008 03:40 PM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 12:55 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
