Aspiring Screw Up..Help! - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-29-2012, 07:56 PM   #46
closed the gaps with 2x6 blocks and cutouts....
lionscourt is offline   Reply With Quote
Old 07-29-2012, 08:13 PM   #47
Originally Posted by CopperClad View Post
Lookin good lionscourt!I would put bird blocking on your walls. http://countryplans.com/smf/index.php?topic=5731.0 Scroll down a little and you will see the bird blocks. Also, not sure if you can see it in the photo, you need to cut a 1 1/2'' x 3 1/2'' notch on your last rafter so you can put your 2x4 outrigger to give yourself an overhang on your sloped walls.-- You don't really need the H2.5 ties on the beam, for your situation it would just be better to cut 14 1/2'' x 2 x 6 blocks , standing them upright in between your rafters. Any questions just ask .
i've got the blocking in (pics) but it get's much sun. do i need vents as well???
Old 08-09-2012, 12:42 AM   #48
nearly done!
man this is hard work...how much should i charge her???? I'm nearly done with roof...ran out of shingles and had to order another bundle....
Aspiring Screw Up..Help!-img00476-20120807-0934.jpg   Aspiring Screw Up..Help!-img00480-20120808-1729.jpg
Old 10-14-2014, 08:20 PM   #49
Never posted finished picks.......this is not but will post pics soon
Sent from my SCH-I545 using Tapatalk
The Following 2 Users Say Thank You to lionscourt For This Useful Post:
BigJim (10-14-2014), mae-ling (10-14-2014)
Tags
emergency help.....
How to repair a ABS soil stack with a drywall screw in it? ThatGuy Plumbing 10 02-22-2012 11:36 AM
I think I put a lag screw into a vent pipe. noone Plumbing 60 01-10-2012 12:13 AM
Azek Decking and Cortex Screw System EdtheC Flooring 2 08-27-2010 08:48 PM
Swapping old 3ways with new (different screw color configuration on new switch) Michblaze02 Electrical 10 11-08-2009 03:17 PM
Can't get set screw in TP holder loose janralix Plumbing 4 08-12-2009 11:47 PM
