Aspiring Screw Up..Help! - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-17-2012, 10:23 PM   #31
Lookin good lionscourt!I would put bird blocking on your walls. http://countryplans.com/smf/index.php?topic=5731.0 Scroll down a little and you will see the bird blocks. Also, not sure if you can see it in the photo, you need to cut a 1 1/2'' x 3 1/2'' notch on your last rafter so you can put your 2x4 outrigger to give yourself an overhang on your sloped walls.-- You don't really need the H2.5 ties on the beam, for your situation it would just be better to cut 14 1/2'' x 2 x 6 blocks , standing them upright in between your rafters. Any questions just ask .
CopperClad is offline   Reply With Quote
Old 07-18-2012, 09:33 AM   #32
plywood
anything I should know about laying the plywood? does the 4x8plywood work better across rafters or going down the length of rafters? It is important to start in one corner and do rows across?
I looked up info on outriggers and understand the need to cut a notch out of last rafter. Is it just one notch at bottom or rafter or a notch for each outrigger for overhang?
Thanks again!
lionscourt is offline   Reply With Quote
Old 07-18-2012, 09:53 AM   #33
You will want all of your outriggers in place(outrigger every 4 feet on your raked walls) and you will want all of your fascia boards installed prior to sheeting your roof. It appears you started your joist layout from the center of the wall, so you will start your first row of sheeting from that point at the bottom of your rake. Lay your entire first row of sheeting cutting the two pieces on both sides of the structure. On the second row of sheeting you will stagger your seams 4ft( half of the 8 ft sheet). You want to lay your sheets perpendicular with your joist.
Old 07-18-2012, 05:57 PM   #34
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Just apologizing if my earlier comments caused any confusion. I didn't look at the pix right and can only say the heat exhaustion must have been getting me worst than normal.
tinner666 is offline   Reply With Quote
Old 07-18-2012, 09:58 PM   #35
'rough' day
Today didn't go that well or according to plan. The 'help' placed several rafters upside down (i mitered back of them for vertical facia) which led a misalignment of whole back row and a hole lot of of pulling nails. In the end I felt like not much got done. I had hoped to be done with the outriggers and on to working on to bird blocks (do i still need them if I plan on framing in vents?).
In the end my back row of rafters are slightly misaligned but did get a good start on blocking. Tomorrow I'm getting an early start and should have pics of plywood sheeting to roof. I downloaded some pictures of outriggers to my phone so am excited about doing that element tomorrow. Thanks E1!
Old 07-18-2012, 11:22 PM   #36
Rewards Points: 2,212
Are your studs nailed together in the corner? can see daylight through.
mae-ling is offline   Reply With Quote
Old 07-19-2012, 11:05 PM   #37
latest pics
Here's latest pics. Girlfriend came over and distracted me with a picnic lunch but got more done anyway.
Old 07-20-2012, 11:02 AM   #38
It would seem to me that it would be better to have one long continuous board for fascia---rather than splicing two 8ft boards (they dont have 20ft fascia at Lowes--you have to special order the longer boards). Splicing two boards would be difficult to attach to outriggers right at seam of fascia?
Old 07-20-2012, 11:23 AM   #39
It would be better to have one piece fascia, but even if you do go to your local lumber yard you would want to put a block mid span along your rake wall outriggers to keep it from rolling.. To do this, lets say your overhang on the rake walls are 12''. You would just cut a 12'' 2x6 and nail it to your outrigger standing upright and then nail it through the backside of the gable rafter. Make sense? If not I will find a photo for clarification.
Old 07-20-2012, 12:11 PM   #40
yes. nail it along side the outrigger and into outside (gable) rafter. Thanks!
Old 07-22-2012, 01:39 AM   #41
latest pic
working on fascia board then roof.....
Old 07-22-2012, 11:21 PM   #42
new pics
could only get a couple hours in today but put fascia up to get some measurements right, and drill miter'd cuts then took it down to prime and paint it.
Aspiring Screw Up..Help!-fascia-down....jpg   Aspiring Screw Up..Help!-day7.jpg   Aspiring Screw Up..Help!-day-7.jpg
Old 07-26-2012, 02:22 AM   #43
bird blocks
Day 8 and Bird Bloks
Aspiring Screw Up..Help!-img00446-20120725-1156.jpg   Aspiring Screw Up..Help!-img00445-20120725-1156.jpg
Old 07-26-2012, 11:36 PM   #44
Day9 Started huckin' 4x8's up a ladder to the roof today and getting them nail down. Will send pics from on top tomorrow. Laying felt by mid day.
Old 07-28-2012, 01:09 AM   #45
plywood
ok...got plywood down on roof. first time doing it so was a learning process. There were a few areas with slight gaps. anything i should be worried about other than nails in gaps??? on to felt and shingles tomorrow.
Aspiring Screw Up..Help!-img00456-20120727-1339.jpg   Aspiring Screw Up..Help!-img00453-20120727-1337.jpg   Aspiring Screw Up..Help!-img00452-20120727-1337.jpg
Tags
emergency help.....
How to repair a ABS soil stack with a drywall screw in it? ThatGuy Plumbing 10 02-22-2012 10:36 AM
I think I put a lag screw into a vent pipe. noone Plumbing 60 01-09-2012 11:13 PM
Azek Decking and Cortex Screw System EdtheC Flooring 2 08-27-2010 07:48 PM
Swapping old 3ways with new (different screw color configuration on new switch) Michblaze02 Electrical 10 11-08-2009 02:17 PM
Can't get set screw in TP holder loose janralix Plumbing 4 08-12-2009 10:47 PM
