Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 12-12-2010, 10:57 PM   #1
Asphalt shingles on vertical wall dormer
We are just completing a small addition with a gambrel roof. One side of the addition has two dormer windows and one "wall dormer" which has no slope (vertical, less than 3 feet wide, located where gambrel roof joins existing house). The wall dormer is currently covered with facia board and painted to match the dormer window trim, but we think it would blend in better if shingled to match the rest of the gambrel roof. Is it possible to put asphalt shingles on this vertical surface? Thanks.
helpplease! is offline   Reply With Quote
Old 12-12-2010, 11:39 PM   #2
Doing This Way Too Long
Have seen it done and laugh every time I see it.
1. It looks really really hokey
2. Half of what I see the laminate separates and falls off.
I don't recommend it.
OldNBroken is offline   Reply With Quote
Old 12-13-2010, 07:47 AM   #3
As in here where the facing gambrel's bottom rake edge meets the main house and you see the triangle of shingles? The difference I suppose is you were adding a gambrel to a standard wall, so it doesn't look normal as in the pic below.
If you do install shingles vertically make sure you at least nail them in the right place (there is sometimes a different line for steep nailing, or just make your nail placement as close a possible to being exposed when the next shingle is put on top), and it may require storm nailing (more nails). I'm pretty sure the last time I read the shingle package it also said hand seal every shingle with tar. Like that ever happens.
I agree that it generally looks hokey to have shingles where siding belongs, if that's your case.
jmiller is offline   Reply With Quote
Tags
asphalt shingles, dormer, shingles
Hanging drywall vertical on basement wall ? Oxymoron Drywall & Plaster 4 02-04-2010 10:58 AM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
CertainTeed Landmark 50 asphalt shingles Wendy Honold Roofing 113 07-03-2008 12:45 PM
Elastomeric coating for asphalt shingles? Arndavis Roofing 1 09-04-2007 11:42 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
