Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-28-2006, 07:34 PM   #1
asphalt shingles
can someone help me?i read in the home depot home improvement book on roofing with asphalt shingles.i want to put architectural shingles instead of three tab shingles.they explain very clearly on how to put down starter row and then trim 6 inches off each shingle until seventh row i think it was.my question is those instructions are for 36 x 12 inch shingles the ones at home depot are 39 and a quarter inch.can i use the same method or is there another?
glassman is offline   Reply With Quote
Old 09-28-2006, 09:30 PM   #2
asphalt shingles
Yes, that should not be a problem.
RussellF is offline   Reply With Quote
Old 09-29-2006, 01:22 AM   #3
renovations
asphalt shingles
The shingles will come with instructions on the wrapper. Depending on the manufacturer, they're all a little different, what you are proposing will be fine, I agree.
Bonus is offline   Reply With Quote
Old 09-29-2006, 06:45 PM   #4
asphalt shingles
russell and bonus,thank you very much.
Old 10-03-2006, 10:08 PM   #5
The Flying Toolbox
handypilot's Avatar
asphalt shingles
If you don't care for reading the torn up plastic wraping, most major shingle manufacturers have instructions posted on thier website.
handypilot is offline   Reply With Quote
Old 10-03-2006, 11:46 PM   #6
renovations
asphalt shingles
The advantage to reading the wrapper is that it IS up on the roof with you, it is referring to the exact type of shingles that you are installing, and it is repeated on every package in case you missed a bit. Also, it doesn't require taking your computer on the roof!
Old 10-04-2006, 01:03 AM   #7
747
registered
747's Avatar
asphalt shingles
Look into Tampko Heritage 30 AR.
747 is offline   Reply With Quote
GAF Roof... the best EdPDX Roofing 73 09-12-2011 06:53 AM
Shingles per bundle redline Roofing 11 09-11-2011 11:41 PM
Masonry Asbestos Shingles, how do I know? ourzoo Building & Construction 8 08-27-2007 09:57 AM
Losing aggregate from asphalt shingle ridge bkspero Roofing 8 07-19-2007 10:40 PM
bending shingles farrington135 Roofing 2 06-09-2007 11:40 AM
