Asphalt Roofing Part List - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-07-2014, 07:07 AM   #1
Rewards Points: 124
Hi, I picked out the architectural shingles and found a contractor who estimated the job very cheap compared to others, and I want to make sure he is not cutting corners to do get the job done. The roof size is about 34 sq.
Attached is the receipt of all the parts (minus 7 roof vents which I'm buying separately). Based on the list, is there anything he may be missing that should be included to do a thorough job? Thank you for your help!!
arminius is offline   Reply With Quote
Old 07-07-2014, 08:25 AM   #2
Rewards Points: 144
I don't see anything he missed.
mako1 is offline   Reply With Quote
The Following User Says Thank You to mako1 For This Useful Post:
arminius (07-07-2014)
Old 07-07-2014, 11:30 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,268
Looks pretty good.
Don't see any ridge vent or pipe collars.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 07-07-2014, 11:40 AM   #4
Rewards Points: 124
I'll talk to him about the ridge vent and pipe collars. How about Exhaust Caps and Furnace Caps?
The Following User Says Thank You to arminius For This Useful Post:
roofermann (07-07-2014)
Old 07-07-2014, 12:12 PM   #5
roofermann's Avatar
Rewards Points: 401
Not enough felt, and #15 is garbage nowadays. probably be short some nails too. Also clear silicone is almost as crappy as latex for roof applications. You want a urethane or tri-polymer based sealant.
roofermann is offline   Reply With Quote
The Following 2 Users Say Thank You to roofermann For This Useful Post:
arminius (07-07-2014), steveinNEPA (07-07-2014)
Old 07-07-2014, 12:23 PM   #6
+1
Figuring that the guy was the cheapest bid, I was guessing he was going to skimp on some materials choices.
Old 07-07-2014, 12:37 PM   #7
Rewards Points: 144
I agree.I always use 30# felt.Makes it easier on the roofer too.They don't have to worry so much about tearing it.
3 bundles H&R perforated:Thought maybe those were vented ridge shingles.
Don't any cap nails for the felt.Some guys staple it but it makes it to easy to pull thru IMHO
The Following 3 Users Say Thank You to mako1 For This Useful Post:
arminius (07-07-2014), roofermann (07-07-2014), steveinNEPA (07-07-2014)
Old 07-07-2014, 02:41 PM   #8
Contractor
Needs to get rid of the clear ultima crap, and use some REAL roofing/flashing sealant.
No ridge vent (weather it be roll out or something like the plastic snow king), cap nails ARE better for underlayment IMO, but staples work too.
Id be using at least 30# felt.
Vent boots arent on there either
steveinNEPA is offline   Reply With Quote
The Following User Says Thank You to steveinNEPA For This Useful Post:
Old 07-07-2014, 03:19 PM   #9
Rewards Points: 652
New skylight flashings, around $100.
If its more than ten years old I would change the skylight too, better chance that is lasts as long as the rest of the roof. looks like a 2x4, should just be a few hundred extra.
PatChap is offline   Reply With Quote
The Following User Says Thank You to PatChap For This Useful Post:
Old 07-11-2014, 04:19 AM   #10
Rewards Points: 850
you get what you pay for. if every one did what this guy is doing we would all go broke. any one whos going to buy, or has, the material is trying to make sure that the installer isnt going to make more than they figure they should. if anyone calls me saying they already have the material, then i say = then you can do it yourself. sounds like you got some fair prices but cant afford them. so you find some one who will do it cheap, why will they do it cheap, because there starving, why are they starving, because they do lousy work. good luck. and now you want someone to verify that they have everything you need. good luck. worse that will happen is that hell do half the job, and do it wrong.
hotrod351 is offline   Reply With Quote
Old 07-12-2014, 11:16 AM   #11
ParagonEx's Avatar
Rewards Points: 150
He's probably cheapest because he is buying his material from Menards and using all inferior materials besides the shingles themselves.
ParagonEx is offline   Reply With Quote
Tags
asphalt roof
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 05:10 AM
Vent Flashing for Low Slope Mineral Surface Roll Roofing Thumbhammer Roofing/Siding 4 05-22-2011 05:52 AM
Asphalt roofing tile recall Frank More Building & Construction 10 01-10-2011 11:09 AM
Procedures qestion new roofing asphalt shingles jones1234 Off Topic 1 07-19-2010 05:21 PM
Multiple Roofing issues on my home. *HELP!* 2bsure Roofing/Siding 4 12-16-2009 09:29 PM
