Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 05-10-2011, 02:06 AM   #1
Asphalt roof shingles
I'm just starting to research asphalt roof shingles to replace an old wood shingle roof. I have gotten a couple quotes: one using CertainTeed Landmark Series shingles and the other using Ownes Corning Oakridge shingles. I live in So. Cal. and was wondering which would be a better material to use.
vlloyd1028 is offline   Reply With Quote
Old 05-10-2011, 09:08 AM   #2
MJW
The one who uses the better craftsmanship and labor.
The rest is virtually irrelevent. The main difference in companies is the labor they use and how talented they are.
MJW is offline   Reply With Quote
The Following 2 Users Say Thank You to MJW For This Useful Post:
Roofmaster417 (05-10-2011), seeyou (05-11-2011)
Old 05-11-2011, 12:03 AM   #3
RFN-4A-LVN
Roofmaster417's Avatar
MJW is right on the money.,But since you are asking,,,I would call your building Department to make sure that you are not required to install a certain type of material for your region.
I would then call several suppliers.I would find out what material is the most common followed by an honest reply from the supplier about which materials have had the most problems in your area.
The inquiry to your building department pertaining to material requirements is because several areas around my location require certain shingle manufactures,grade,quality and colors.
If I were to choose between Certainteed and O.C,,I would choose Certainteed any day of the week over O.C,,,but that's my opinion.
Roofmaster417 is offline   Reply With Quote
Old 05-11-2011, 06:42 AM   #4
Shut in w/o Home
seeyou's Avatar
X2 on the Certainteeds. But it's mainly because the local rep is much more responsive than the reps for other brands, not so much the material.
seeyou is offline   Reply With Quote
Can I put shingles (or gravel) on top of torch-down roof? cbru Roofing 11 11-17-2010 11:24 AM
Help! -- what is causing these shingles to fail? imaginator Roofing 1 09-18-2010 07:29 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
Storing shingles on roof GerryinBelleRiv Roofing 1 09-03-2009 08:13 PM
Metal roof vs asphalt shingle roof Bob_T Roofing 1 06-20-2009 06:51 PM
