Asphalt Or Fiberglass? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-15-2008, 09:06 AM   #1
Rewards Points: 123
asphalt or fiberglass?
I don't know if I should put this under a new thread or not.Is asphalt shingles the same as a fiberglass? If it isn't which is better?
jerry1967 is offline   Reply With Quote
Old 04-15-2008, 09:19 AM   #2
Yes they are one and the same. They are called fiberglass because these asphalt shingles have a fiberglass mat. The fiberglass mat has proven to be more durable than the older organic mat shingles. The more popular brands such as Certainteed have fiberglass mats.
Abraham Lincoln is offline   Reply With Quote
Old 04-15-2008, 02:45 PM   #3
Nearly all shingles are made with an asphalt composition, with the exception of the ones made of modified bitumen.
Organic shingles have a center reinforcement core composed of an organic asphalt saturated material. Sometimes these are erroneously called asphalt shingles.
Fiberglass shingles contain a fiberglass reinforcement core which provides superior reinforcement strength, as long as it is a higher weight quality shingle.
Nearly all of the higher end shingles, called architectural shingles are composed of the fiberglass reinforcement core, if that tells you what the manufacturers think.
Ed
Ed the Roofer is offline   Reply With Quote
Old 04-15-2008, 06:57 PM   #4
Rewards Points: 123
thank you very much!!
Torch Down Instructions Needed - DIY MikeinBurien Roofing/Siding 86 10-07-2012 12:21 PM
Is fiberglass insulation safe for us with dishwasher? jen78fl General DIY Discussions 10 01-31-2008 06:51 PM
Depth of Crushed Asphalt cibula11 Building & Construction 4 09-26-2007 01:24 PM
Using fiberglass filler on a balcony darsunt Painting 2 12-31-2006 09:13 PM
