Asphalt - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-12-2011, 06:47 PM   #1
Rewards Points: 16
asphalt
I was told type 3 asphalt is better than type 2 asphalt for roofing, any help would be appreciated.
Alec
Alec is offline   Reply With Quote
Old 05-12-2011, 09:23 PM   #2
It depends on the slope of the roofing system and/or decking.
Type III will not run as readily as Type II, which is better to prevent asphalt drippage down the road.
BUT, a more viscuous product has more potential for self-healing any small imperfection type pin-hole leakage gaps.
So, the right answer, between the 2 types is what is it's intended end usage?
Coal Tar Pitch would be better than any of the more viscuous asphalts, btw.
Ed
Ed the Roofer is offline   Reply With Quote
Old 05-13-2011, 06:01 AM   #3
Rewards Points: 16
The roof is a flat roof with minimal slope. And the deck is metal. Which aspalt will stand the test of time longer type 2 or 3? and it is a 4 ply bur roof.
Alec
Old 05-13-2011, 12:27 PM   #4
Low Slope Roofing
Rewards Points: 114
Generally speaking type III and type IV are most often used. Depending on slope. CTP is great also, most people are afraid to work with it.
1985gt is offline   Reply With Quote
Need advice on 1 1/2 inch of asphalt overlay on concrete and old Asphalt stanlam Off Topic 9 12-05-2010 07:46 PM
Need advice on 1 1/2 inch of asphalt overlay on concret and old Asphalt stanlam Landscaping & Lawn Care 1 11-28-2010 04:50 PM
Asphalt patch/fill/seal with concrete involved brokenknees Building & Construction 1 10-29-2010 02:30 AM
Asphalt shingle siding over cedar shakes Catguy Building & Construction 1 04-05-2010 09:10 PM
Asphalt Question javan General DIY Discussions 5 07-16-2008 06:38 AM
