Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 06-19-2010, 10:33 AM   #1
Asbestos Shingles
What is the procedure for removing asbestos shingles in Dallas? Is a premit requied?
batt is offline   Reply With Quote
Old 06-19-2010, 05:54 PM   #2
Asbestos Shingles
Here in NC (at least when I had to deal with the question about 12 years ago) it depended on whether or not it was a flexible asbestos roof or the solid type. The flexible one could be disposed of like other shingles. But the frissable ones(not sure if that is the correct word or spelling; that is it produces a dust when sawed or broken) --, like a solid tile-- required special handling. So it might be pertinent to getting an accurate answer to explain what type of asbestos roof you are dealing with.
Alto is offline   Reply With Quote
Old 06-19-2010, 06:02 PM   #3
Tom Struble's Avatar
Asbestos Shingles
depends some states let the homeowner remove them without a permit,some don't you really have to check your state for the requirements...then check to make sure you can get rid of them
Tom Struble is offline   Reply With Quote
Old 06-19-2010, 06:30 PM   #4
Shut in w/o Home
seeyou's Avatar
Asbestos Shingles
Here, the HO can remove them, but disposal is by license only. Causes a lot of them to go in the sink hole or the crick down in the hollar.
seeyou is offline   Reply With Quote
Old 06-20-2010, 09:14 AM   #5
Asbestos Shingles
yea i should have said...legally dispose of them
painting on asbestos shingles BRHandyman Painting 3 11-03-2009 01:11 AM
Fastening something to asbestos shingles troyce1 General Discussion 2 07-05-2009 03:39 PM
Adding stove top vent - cutting asbestos shingles t_mccann Building & Construction 6 11-29-2007 04:59 PM
Masonry Asbestos Shingles, how do I know? ourzoo Building & Construction 8 08-27-2007 09:57 AM
Asbestos Shingles jkrodger Building & Construction 11 07-22-2007 04:55 PM
