Anybody Ever Use This Patching Material? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-02-2012, 04:14 PM   #1
Rewards Points: 1,062
Anybody ever use this patching material?
Its here:
http://henry.com/sealants/roof_multi...atchroofcement
They told me you dont need to apply the classic roofer's mesh with this stuff. Seems too easy/good to be true, but geez, I hope it performs as advertized.
Figure maybe some guys here could advise me/warn me. OR, should I use it WITH the 4" mesh?
Thanks!
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 04-02-2012, 05:23 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
It doesn't say it's compatible with APP, or SBS. It it's not, don't use it on either. Same for any shingles.
Maybe you have a tar and gravel roof? If so, bump off the rock in the area of the leak first.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
noquacks (04-02-2012)
Old 04-02-2012, 07:19 PM   #3
Doing This Way Too Long
Rewards Points: 532
I don't know who "they" are but "they" are wrong. Plus it's a henry's product...nuf said.
For an optimal repair and longevity, some type of webbing or reinforcement skrim should always be used with any type of mastic or liquid repair.
You CAN use it by itself but it won't last long.
OldNBroken is offline   Reply With Quote
The Following User Says Thank You to OldNBroken For This Useful Post:
Old 04-02-2012, 08:06 PM   #4
Good tip, Old. I figured "they" were wrong. They are HD. Figures. I will use the mash- I knew it was too good to be true. I know I should get at least a year out of it, if patched/webbed right.
Old 04-02-2012, 08:40 PM   #5
Rewards Points: 532
Good show
Replacing underlayment in entire house...what material to use? Dave321 Flooring 23 12-23-2011 03:38 PM
Water Fall - Black bonding material cprao Landscaping & Lawn Care 3 04-23-2011 04:06 PM
Smoothing Joints Between Sheetrock and Plaster Without Sanding OldManMike Building & Construction 6 06-30-2009 08:42 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 08:41 PM
