Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 06-03-2010, 01:04 AM   #1
Any experience with Malarkey shingles
Hello, I hope to gain some insight as well on roofing. We are looking at replacing a 3 tab roof(leaking ceiling) with either the Malarkey Highlander or Pabco Premier 30. I have seen both and the noticeable differences are in 1. the thickness(Pabco is thicker) and 2. the pattern of the shingles; malarkeys pattern flares out(I'm told by the other guy this can cause needles to lodge in the crevises down the road) whereas Pabcos shingles wedge in,. Both have algae blocker. Pabco uses felt underlayment, Malarkey uses Nova Seal II /WaterBlock Ru 200. Now I understand that the Highlander does not contain the rubber like the Malarkey Legend shingle so I'm not sure what I'm comparing. All that I have read about Malarkey seems good,although there is alot of Malarkey marketing out there. ...no pun there. Any insight greatly appreciated.
Lizybizy is offline   Reply With Quote
Old 06-03-2010, 01:43 AM   #2
i'd go look at them all. i'm also doing a roof on my house and did just that. my favorite of the 30yr shingle was the certainteed landmark. any reason? nope, just cosmetic. malarkey and corning were a close second with their version of the same shingle. i just liked the certainteed color more, they also appeared thicker. our local roofing outfit is called woodfeathers and they have big displays set up so you can view everything, if there is a similar store in your town i'd go pay a visit. every single quality roofer i spoke with told me the same thing. it's all in the quality of installation. if you don't cut corners, any of the major brands will work.
racebum is offline   Reply With Quote
Old 06-03-2010, 08:39 PM   #3
Thanks! I actually did check them out . I think what I'm asking is am I going to be reroofing in 10 years if I go with the economical "Highlander" shingle by Malarkey or can I expect a good quality shingle at a reasonable price. I have not heard anyone mention using this particular shingle which leaves me a little leary.
Old 06-03-2010, 09:40 PM   #4
there's one malarkey shingle that i really liked. it was on sale for $58/sq and looked a lot like the certainteed landmark or corning oakridge, is that the highlander? i think it was but can't swear to it
it's all in the install though. in my roofing thread there is a near failed pabco roof that's maybe 10 years old. the install was a total hack and thus the reason i have to replace a roof that only lived a third of what it should have.
Replacing chimney flashing after new shingles tmiles2246 Roofing 18 04-18-2011 02:03 PM
Difference between "heavier" shingles, and "wind resistant" shingles Inquiring Mind Roofing 4 02-03-2010 04:21 PM
Weight vs. durability of architectural shingles JoeT Roofing 10 06-29-2009 07:50 AM
IKO Shingles - beware mtugrad1985 Roofing 7 02-10-2009 04:42 PM
Any experience with Malarkey shingles? Bob D. Roofing 2 07-07-2007 03:29 AM
