Another Venting Question - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-03-2012, 08:03 PM   #1
Hi Guys, I have been lurking on this website for a while and its been very helpful. I am getting ready to re-roof my house. I am going from shake roof to asphalt shingles (Certainteed Presidential). I have been reading up on codes and trying to get all the research done ahead of time so I don't have to many suprises once I start the job in september.
My first question is regarding Title 24 compliance. I want to make sure I am meeting the requirements (California Resident). Here is what I have calculated. Can someone confirm this is correct? If not point me in the right direction?
45ftx50ft=2250ft2
2250 ft2 of Attic /150= 15 ft2
15ft2 * 144/2= 1080 sq in
Soffit vents are 40 NFA
1080sq in/40sq in= 27 Soffit Vents Needed
Ridge Vent
1080sq in /17 in per lin ft=63.5ft of Ridge Vent needed
So if I am correct it is saying I need 27 soffit vents and 64 ft of ridge vent to meet compliance?
rpratt84 is offline   Reply With Quote
Old 07-04-2012, 06:24 PM   #2
Bump? Anyone?
Old 07-04-2012, 07:30 PM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
You seem to understand and have correct the formula e for the T-24 requirements. It seems like your ridge vent calc is low though.
Now, usually for a re-roof you don not need to bring the venting up to code although this particular code has been around for a long time.
I usually only have to spec the venting if there is going to be new roof area.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 07-12-2012, 03:17 PM   #4
Andy thanks for your input, I do have a question. You said:
"Now, usually for a re-roof you don not need to bring the venting up to code although this particular code has been around for a long time."
So does that mean I do not need to bring it up to code? From my reading I thought this law went into affect in 2010 including re-roofs. Can you give me more details?
As it is right now I have 9 soffit vents. If I was to put 27 in then I would have essentially no bird blocks in between the trusses. When I watch all the roofing companies around here reroof I dont see them putting in all these soffit vents. I just want to make sure its done right and I pass inspection.
Thank you
Dryer Venting Question jabond Appliances 2 06-21-2012 03:08 PM
Venting question Sammy 2 Plumbing 2 02-14-2011 08:57 PM
Question about dryer venting jimithing78 HVAC 10 08-26-2008 11:37 AM
Rheem classic 90 plus venting question jjconst07 HVAC 2 07-04-2008 05:14 PM
venting question any pros? THEBIGPUNN Roofing/Siding 3 02-06-2006 08:19 PM
