Another Membrain Leak Problem. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-02-2010, 10:02 AM   #1
Another membrain leak problem.
I have a leak in the roof membrain somewhere. I say somewhere because I simply cannot tell where it is. I have flushed the area with a garden hose and apply far more water than a light rain will deposit. However, I can barely get a drip. It appears water it is running down an exterior vertical metal support beam, rusting out the joint between two horizontal metal beams, and deterierating the plywood sofit. There are no leaks in the scuppers nor is there evidence of leakage of the drainage couplings and piping. I don't know what to do next.
HoldenMcGroin is offline   Reply With Quote
Old 09-03-2010, 08:22 AM   #2
Grumpy's Avatar
Rewards Points: 540
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Pictures of the roof area would help. It could be coming in a wall and traveling along beams. If there are multiple layers it could be coming in anywhere and rivering between layers and showing as a leak in a completely other area.
You can have an infrared scan performed. There are also low voltage tests, which I am not all that familiar with, both of which shold be performed by trained professionals and won't be cheap.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
16 years old and small leak, time to replace? supermaxhd HVAC 16 05-19-2010 07:09 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
Roof leak around my chimney - update GlennAble Roofing/Siding 3 11-05-2009 06:24 PM
Leak on gas heater water line? darsunt Plumbing 3 04-16-2008 03:57 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
