Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 04-13-2010, 09:55 AM   #16
Another Flat roof tear off and replace post
Hi Aaron,
Yes you are probably correct, I am not sure what the current roofing is called. The roofing is a rolled gravel type of material. I swept a ton of it off. It has been painted silver by a roofer who said it will protect it longer. Guess what, he painted it silver last summer, now it has a ton of cracks and leaking.
I will definitely not reuse the counter flashing. The pictures don't show it, but it is heavily damaged, has rot holes in it, and I don't want to take chances with it. I am going to replace it with copper 100%.
When I cut out the holes for the suntunnels, the roofing looked to be about 1" thick. I tried to count the layers, and it seemed to be about 7. I am not sure if I counted correctly, but it looked like too many layers. The hole was 14" diameter, I didn't weigh it, but it felt massive. I cannot even guess how heavy it was, as that was nearly 3 years ago.
You can see I put down the torch roofing around the suntunnels and all other protrusions. At the time I had a bad feeling about putting another layer of roofing throughout, due to my suspicion of already having too many layers, I think I was right. Those sections with the torch roofing are the only ones that do not have any cracking, bubbling, or any visible damage.
I can grind out and re-point the walls no problem. I am also thinking of putting a strip of BUR between the wall caps and the counter flashing, do you think that is a good or bad idea?
slickgt1 is offline   Reply With Quote
Old 04-13-2010, 08:12 PM   #17
Commercial Roofing
AaronB's Avatar
If you're going to re-point the walls properly, then there should be no need for a membrane at that point.
A through-wall flashing may be a good idea, though.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 04-14-2010, 09:46 AM   #18
Thats good too.
Do you see that skylight by the roof entrance? I plan on replacing that, and making a proper roof access door as well (something that will just open on hinges, not something I have to move to the side every time). Do you think it is a good idea to get something that is curb mounted? Or should I replace with something similar?
Thanks again. Almost done with the planning stage. Planning to get this started sometime May 19th.
Old 04-14-2010, 11:02 PM   #19
Commercial Roofing
AaronB's Avatar
There are curb mounted hatch cover for this purpose that swing upwards and lock open/closed.
They may seem a bit pricey, but IMO worth every penny. Some even come with safety rails designed so that it is much more difficult to accidentally fall in.
Old 04-15-2010, 09:40 AM   #20
That is exactly what I am looking for. The one I currently have is BS. Even with going up on the roof a couple of times a year, I don't like that I have to put that cover on the roofing, and then drag it back to close it. Plus for some reason it weighs a ton.
Do you know of a brand that I should look for? I know of Velox and thats pretty much it. Do you think they carry what I need, and would I be able to get a custom size? Thanks again.
Old 04-15-2010, 12:11 PM   #21
Commercial Roofing
AaronB's Avatar
http://www.bluewater-mfg.com/App_Roof-Hatch.htm
Old 04-15-2010, 02:04 PM   #22
Thank you very much.
Old 05-03-2010, 10:28 AM   #23
Hi guys. Was at the roofing supply this weekend.
Ordered cant strips, GAF base sheet, Firestone top sheet, copper counterflashing, primer, nails, flashing cement, and silver paint.
The owner suggested I get insulation panels under the base sheet. Should I consider this? I have insulation between beams on the inside of the house. It could be a good idea as far as leveling out any missperfections on the decking once I tear off the old roofing.
Thanks in advance.
Old 05-03-2010, 10:33 PM   #24
Commercial Roofing
AaronB's Avatar
If you have a space between the celing and roof deck, then insulation would most likely be a waste of money. Cover board would do the same thing for deck preparation as insulation boards and at a fraction of the cost.
The Following User Says Thank You to AaronB For This Useful Post:
slickgt1 (05-05-2010)
Old 05-04-2010, 11:47 AM   #25
Hi Aaron,
Thanks for the reply.
Inside the house, I have the roof deck, right under it is Bat Insulation, under that are the ceiling joists, under that is sheetrock. Bat insulation is against the roof deck, about an 1-2" between insulation and roof deck.
I am going to upload pictures of this during the construction phase. I hope it will show this for better understanding.
Old 05-04-2010, 12:02 PM   #26
Ok, insulation between roof joists. You can see the metal studs for the sheetrock. In this area, the space between the roof joists and ceiling is big, about a foot. That gets less as you go toward center of the house. I am not sure if this is what you are talking about.
You can also see the roof thickness in this picture under the skylight curb.
So should I do insulation panels on the roof, or just cover board? Thanks again, you've been great help.
Old 05-05-2010, 10:35 AM   #27
TTT, Thanks.
Oh forgot to add. There is spray foam insulation between all the metal, ceiling and walls. Don't have a picture of that. Pictures were taken for locations of wires and pipes, once the insulation was sprayed, everything is white. Sorry.
