Angled Soffit - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-14-2008, 10:02 AM   #1
headache
angled soffit
hello, need your help , on my house the soffit is plywoood with alum. vents every 8 ' , i would like to replace with alum. or vinyl , problem is rafters are at 10/12 pitch , this is the way soffit is ran also ,because if you try to box them in there is no room for window or door trim. my question is can i run new soffit at this angle (alum. or vinyl) ? hope you can understand my question , i'm confused & i wrote it. thanks.
headache is offline   Reply With Quote
Old 07-14-2008, 09:37 PM   #2
I understood your scenario well enough.
Yes, you can have the Aluminum Soffit panels run parallel to the existing soffit panels.
I would cut away the middle 80% of the existing plywood, making sure that the remaining 10% on each side is securely fastened and then install a 100% vented aluminum soffit panel to allow additional fresh air intake ventilation into the attic structure.
Vented panels cost the exact same price as the solid, unvented panels, so thake advantage of this opportunity now and do it right.
More than 90% of all homes have inadequate ventilation and usually are even shorter of the requirements, when it comes to the intake aspect.
Ed
Ed the Roofer is offline   Reply With Quote
The Following User Says Thank You to Ed the Roofer For This Useful Post:
craig11152 (08-12-2015)
Old 07-14-2008, 10:45 PM   #3
the roofing god's Avatar
Send a message via MSN to the roofing god
ED is correct on all,except vinyl is the material of choice today
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 07-15-2008, 05:35 AM   #4
headache
angled soffit
thanks for advice, i like the look of the boxed in soffit , not sure if i could acheive this by maybe cuting rafter tails off a few inches raiseing the height to miss trim , please comment . thanks, jim
Old 07-15-2008, 10:54 AM   #5
Yes you could, as long as you get the plane above the window trim.
Ed
Old 08-12-2015, 01:04 PM   #6
Rewards Points: 2
Hi Ed or others, when installing the angled soffit that Headache asked about, do you use a special J channel? If not, how do you get it to bed open to accept the soffit sheets when it is at such an angle to the direction you want the soffit to run?
Mudduck33 is offline   Reply With Quote
Old 08-12-2015, 01:19 PM   #7
Rewards Points: 144
I usually use double j or cut and bend a piece of j to match.Cut the top and bottom of the flange on the j to fit.
mako1 is offline   Reply With Quote
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing/Siding 2 04-30-2007 11:14 PM
Older house, no soffit vents- what to do? nebben Roofing/Siding 3 01-24-2007 02:37 PM
Installing Soffit and Facia??? Vikeologist Roofing/Siding 3 11-15-2006 05:01 PM
Removing ductwork in soffit... inovermyhead HVAC 2 04-02-2006 10:56 PM
Soffit installation question milano Roofing/Siding 4 02-04-2006 10:13 PM
