Andalusa Clay Tile From Honduras - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-24-2004, 12:30 AM   #1
Guest
Guest
Posts: n/a
Question
Andalusa Clay tile from Honduras
I am having a new Clay tile roof installed in Dallas, Texas. Some of the tiles have surface pops ranging in size from a dime up to a quarter. All of the "surface pops" have a white chalk like substance at the center of the pop. Three or four have surface flaws that may trap moisture. I was told by the tile rep. that it is normal for clay tile to have some of these imperfections and surface pops. There are probably about 10 pops in about 3 squares of tile so far.
Is this the truth or a load of you know what?
Any comments on this tile or its imperfections?
The tiles are "Andalusa" made in Honduras.
tj.sanders@sbcglobal.net
TIA
Old 09-28-2004, 12:47 PM   #2
Guest
Guest
Posts: n/a
Talking
Solved my own problem. Asked the Tile Rep to put it in writing! He said not until he is paid! That was enough. His tile is coming off the roof and another is going on!
Old 11-28-2004, 12:45 PM   #3
Good for you! Listen on tile: buy and install only local products the reason is simple: At some point you'll have to replace a few tile or more than a few tile. What ever roof you go with maintaining it is part of owning it, and tile is is a real pain if you run out, and need more, and it's made in a some other country! Also know this about tile: the tile isn't the working roof, its whats under it- that is the working roof!
johnboy52 is offline   Reply With Quote
Old 06-29-2013, 09:39 AM   #4
roofingquotes's Avatar
I agree on buying products locally you don't want to ran out pieces during the roofing process. The good thing about it you can check the product yourself.
roofingquotes is offline   Reply With Quote
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
Tile roof questions/repairs help please xoroniox Roofing/Siding 3 12-17-2006 03:02 PM
Painting a terra cotta clay tile roof? xoroniox Painting 2 12-13-2006 01:30 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
