Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 11-18-2012, 10:52 AM   #1
Question
Am I getting Screwed by Roofer?
I am having a new EPDM roof installed on a 220 sq flat roof. It is not quite done and I am paying 10k for this roof and an Aztek railing. I noticed yesterday that under the New EPDM there are several areas that have debris under the EPDM on top of the ISO Board. They didn't clean it off well enough I assume. The Roofer assures me it is not an issue and that there is No fix for this. I have little exp with roofs. I'm not paying this amount of money for crap work, but not sure what to do. What would you all do??
rainyb is offline   Reply With Quote
Old 11-18-2012, 11:00 AM   #2
Exterior Construction
Windows on Wash's Avatar
Post up some pictures.
I think you mean Azek railing.
Sounds a bit steep from a cursory reading of it.
Old 11-19-2012, 08:42 AM   #3
Pro Slate Roofer
tinner666's Avatar
The fix is to work slowly looking for pieces of ISO stuck to itself or the EPDM as it's rolled into place. The roller picks pieces up and the wind blows pieces of foam around, but picking it out as the EPDM is rolled into place IS the norm.
220 sq, or 220 sq. feet? Big difference there. A sq. is 100 sq. feet in roofing terminology.
Frank
tinner666 is offline   Reply With Quote
Old 11-19-2012, 11:42 AM   #4
+1
I was reading it as 220 sq/ft.
If it was 220 squares...that is the deal of a lifetime.
Old 11-24-2012, 09:28 AM   #5
220 square for 10000 bucks??? or 220 square feet for 10000 bucks either way it doesn't seem to make sense to me...
guynextdoor is offline   Reply With Quote
Need Opinions ASAP - Roofer causes expensive problem with furnace MB1 Roofing 9 06-20-2012 10:04 PM
screwed a few screws into a stucco ceiling..how screwed am I? vi_lontano Remodeling 6 02-15-2012 08:56 PM
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing 1 09-07-2011 11:13 AM
Leaking Ceiling, Do I Need a Roofer? Phreek Roofing 31 04-09-2011 04:24 AM
Would this be a good deal for a roofer or is it a dumb thought Doug Crf Roofing 5 05-09-2006 11:44 PM
