Am I Asking For Future Problems With This Project? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-27-2010, 07:56 AM   #1
Am I asking for future problems with this project?
I am on the North/South Carolina Border and it gets pretty hot here.
I have converted an old screened in porch to an open air patio and am adding tongue and groove panels to the ceiling.
My concern is that the extreme hot air will get trapped between the roof and the ceiling and possibly warp the ceiling or worse.
Can anyone provide a solution for this?
Should I use some sort of venting or insulation or both?
Thanks in advance.
vintagerider is offline   Reply With Quote
Old 07-27-2010, 08:06 AM   #2
Here is another pic
Again thanks for any and all advice....
Old 07-27-2010, 11:02 AM   #3
Sorry to answer my own post but...
Should I use foil sheathed foam panels (with the shiny side facing upwards) as an option?
I have searched the boards here and elsewhere and cannot seem to find an answer. Would like to resume the project but am fearfull that once I finish attaching the T&G it will be too late.
Old 07-27-2010, 08:05 PM   #4
Doing This Way Too Long
Rewards Points: 532
Are you enclosing the porch or just finishing the ceiling? If you are not enclosing/heating it, insulation won't do any good and venting probably won't be necessary as you won't have any appreciative temperature differential between the top and the bottom of the deck. Warpage occurs when you have varying temperature and humidity differences between the two sides of the deck. I think you will be fine.
I like the look of it in the pictures.
OldNBroken is offline   Reply With Quote
Old 07-27-2010, 08:51 PM   #5
Rewards Points: 1,088
It depends on how your patio roof was built. You can probably add ridge vents, but make sure you have intake also.
handy man88 is offline   Reply With Quote
Old 07-28-2010, 04:40 AM   #6
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
It won't hurt and may help. I have seen cases of porch roofs in direct sun radiating heat through the ceiling consequently decreasing the porch's comfort level. As mentioned above, venting the roof would also help.
What's the roof surface?
And by the way: nice looking job.
seeyou is offline   Reply With Quote
Old 07-28-2010, 07:16 AM   #7
PRS
I usally just put vents.
PRS is offline   Reply With Quote
Old 07-28-2010, 07:49 PM   #8
Venting
Please excuse my ignorance....I am a truly a dedicated DIYer.
But.....would I be okay if I simply addded a vent on the lower edge of the 18 foot shed roof or do I have to add a return on the side attached to the house. If so, would that house side vent be vented down into the patio area or up through the shingles(I hope not).
Jim's downstairs bathroom project Jim F Project Showcase 90 03-18-2011 10:02 PM
Would like to share a project my wife & I completed this spring. pinwheel45 Flooring 7 08-12-2009 11:02 AM
Owen or Certain Teed has less problems?? reeses Roofing/Siding 10 02-07-2009 08:35 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
Moisture problems when 'heating only when needed' in insulated garage? timg HVAC 10 01-18-2007 05:38 PM
